Advice before I install Progress Coilovers? - SR20 Forum
Old 01-08-2009, 03:59 PM   #1 (permalink)
1991 SE-R original owner
After waiting 3 months to get my coilovers, they are finally here. They were delivered on Christmas Eve. Merry Christmas to me! Okay, I know I don't post much at all, but I've been reading your posts for a while, so hello to everyone.
Before I install my coilovers on my '91 B13, I was wondering if there is anything else I should do or purchase before I take everything apart? Anything I need to replace while I have the suspension apart?
Thanks in advance.
Matt
MattS is offline   Reply With Quote
Old 01-09-2009, 10:50 PM   #2 (permalink)
wants 2 dry hump chriscar
Feedback Score: 8 reviews
check all your bushings and see if they are in good condition.
Old 02-13-2009, 12:24 PM   #3 (permalink)
bitemyshinymetalass
SuperblackZ's Avatar
Tie rod ends, check, LCA bushings good time to go poly if you're so inclined. Hub bearing depending on age of car. Whenever you tear all that apart, you're going to want to get an alignment, so think about parts impacting that.
Also if you're not using a camber plate front setup, when tightening the tops push the top in toward the center of the car. This will give you a tiny bit more camber because of the small amount of slop in the strut top mounting holes.
In the rear if you have any inclination for a RSTB now would be a good time to put one in, see Octotat's thread here.
Then sit back and smile, because if you like your new Progress CO's half as much as I've liked mine, you're going to be very happy.
SCC Project SE-R
'91 B13 Black, 10:1 JDM, O.E.M. CAI Intake/ JWTPopC, SSAC Header, UR Pulleys, JWT Stage 2 Clutch/ECU, Progress CO's 450F/350R, Progress F&R SWB, GC Plates, FSTB/Firewall brace, Progress LCAB, ES bushings/MM's, Wilwoods, Traklites 15x7" Kuhmo XS/Kosei K1's/NT01's, Chuck's RSTB, KOYO rad, R32 Wheel/Horn, R32 Shift knob
Team Progress, Track Vids,My 2nd '91 B13
SuperblackZ is offline   Reply With Quote
Old 02-13-2009, 12:25 PM   #4 (permalink)
bitemyshinymetalass
WHAT'S that line say below your member name???
Old 02-13-2009, 01:34 PM   #5 (permalink)
Oh I do enjoy it. Man, what a difference. Thanks for the suggestions.
Old 02-13-2009, 02:03 PM   #6 (permalink)
bitemyshinymetalass
If you haven't picked up their front LCA brace, highly recommend it. It does a great job of tying the front of the car together:
Their sways are good, too, but the LCA really impresses me having had it off and on the car, what a difference.
Old 02-13-2009, 02:53 PM   #7 (permalink)
Sentraholic
Feedback Score: 5 reviews
where can I get one of these? I've never seen this LCA before... Thats a [B]FAT [B] sway bar by the way
E = mc NISSAN
det-ser92 is offline   Reply With Quote
Old 02-13-2009, 03:38 PM   #8 (permalink)
Kicking it over @ g20.net
u sentra guys have all the goodies
enohand is offline   Reply With Quote
Old 02-13-2009, 03:46 PM   #9 (permalink)
bitemyshinymetalass
call
Joey Berry
1.800.905.6687
www.progressauto.com
mention Steve T and hope he doesn't hang up
yes it is, 33 or 35mm, it's freakin huge!
Old 02-13-2009, 03:51 PM   #10 (permalink)
vengeance
Feedback Score: 7 reviews
that setup is awesome! i want it. but i have a b14
its simple, start s**t, get shot.
Taurus45acp is offline   Reply With Quote
Old 02-13-2009, 04:04 PM   #11 (permalink)
bitemyshinymetalass
IDK about the LCA brace, but they do same level of sways for B14
edit: 91-94 only
http://www.progressauto.com/products...D2/47/sfID3/70
Old 02-13-2009, 07:08 PM   #12 (permalink)
Yep, that is one of the next things on my list. This is the first suspension mod I've done in a while. I had some blown Tokico blues on there and some old Eibachs. Bounce baby, bounce. And not in a good way.
So the LCA brace, and I'll probably swap out my ST rear sway for a Progress sway, then maybe a rear strut bar. Then I'll be
