Camber and toe question - SR20 Forum
Old 01-28-2009, 01:20 AM   #1 (permalink)
I have a b14 with tein basics and camber plates. I put them on around may last year and I also made the big mistake of never getting an alignment so my tires got destroyed pretty quickly. what do you guys suggest I set my camber and toe to so I can get decent tread wear and not compromise handling. I read that about 2.5 degrees of negative camber and 0 toe would be suitable for my situation is that correct or would that create too much tread wear? Thanks guys!
nismosigma is offline   Reply With Quote
Old 01-29-2009, 06:56 AM   #2 (permalink)
Bump!
Old 01-29-2009, 07:50 AM   #3 (permalink)
Feedback Score: 18 reviews
toe really kills tires you might want 0 toe with a tad of camber so you sound like your on the right track
Project Shift_Rebirth
i buy blown trannies
Nyc Sr20PowerD is offline   Reply With Quote
Old 01-29-2009, 11:50 AM   #4 (permalink)
from FrontWD to RightWD
Feedback Score: 6 reviews
unless you are racing, you REALLY want zero toe. toe wears out tires the fastest. i guess for racing, you can run like a degree of toe out and it helps with corner entry. as for camber, 2.5 degrees is alot. when i had my NX i MAXED out the exc. bolts and only got 3 degrees. 1 degree of neg camber is great for DD or weekend warrior
Old 01-29-2009, 07:29 PM   #5 (permalink)
thanks guys I think im going to go with 0 toe and 1 degree or 1.5 of negative camber.
