Sorry my camera died during the fking install, but it was quite simple to do. Just removed the top 3 strut tower nuts on the front and the 2 massive 17mm bolts holding the strut to the front control arm and the stock crap suspension comes right off. Anyways after the install, which took about 2 hours, with the help of an air impact wrench (never leave home with out it) I drove the car about 10 miles to my parents place where I am going to have it hang out for a week while I am away on business.
But the 10 miles was much fun, I didn't go all out because I am not sure exactly how the car is going to react now, plus the alignment is completely off. But I did do a few aggressive maneuvers and boy the handling is RAZOR sharp and the ride quality is awesome.
The basics are lighter than the stockers and they are also shorter, the car has been dropped about 1.2 inches in the front and 1.5 in the rear. Body roll is down to a minimum and this is before I install my Cusco fstb, octotat rstb(pending purchase), and rear anti sway bar. The only weakness I found in the suspension was the mounting of the brake line bracket, that was a BITCH. I got very dirty doing the installation but it was well worth it. I also installed my AEM cold air intake. It was actually for a 94 sentra, but I just had to do a few modifications with a cutting wheel to one of the mounting brackets and also had to grind down my fender where the battery tray goes, this was more difficult than actually installing the entire suspension setup.
I also never realized how ugly the stock intake system is
. Anyways I need to get a shim for the hole surrounding the secondary tube on the intake, so I am thinking about shooting some expanding foam around the area to keep it nice and solid. I also need to tap the secondary so i can mount the air intake temperature sensor, since there is not a place for it on this intake.
These are just minor details, once I get the car realigned, a resonator installed on my exhaust and the rest of my suspension components installed. This car is gonna be soooooooooo much fun to drive this summer. There will be many videos to follow
Ill get pics up ASAP of the finished products. I need to drop my artillery off at my folks place for safe keeping while im not at home, so ill be taking pics of the awesomeness then.
