Bump steer kit question (part wear) - SR20 Forum
Old 03-15-2009, 04:09 PM   #1 (permalink)
starting over
Feedback Score: 3 reviews
I purchased a bump steer kit a little more than a year ago in this thread :
http://www.sr20forum.com/suspension-...-uprights.html
Until my last weekend at VIR everything was in perfect working order. Shortly after my first session I developed a vibration at speed. This worsened with the more miles driven. I checked for wheel play and I have some. I would describe it as toe play and not bearing play. It moved at the 9 and 3 position and not the 12-6 I am wondering if it is the spherical bearings or simply the inner tie rods. Do the bearings wear in such a way that I would feel this play or should I look at other components
SoloSol is offline   Reply With Quote
Old 03-18-2009, 03:36 PM   #2 (permalink)
Not on fire... yet
If you jack the front end up and wiggle the wheel left to right you should be able to see where the play is...
I would guess inner tie rods or steering rack bushings but if the "vibration" sounds like it is based on speed, I would point at the wheel bearing first.
Hope that helps some...
93 NX2K
-dents, bbdet, GC's, air/water IC, AC, etc...
1988 BMW M3
-evo 2.5L stroker
2008 4Runner Limited V8
-stock (I need one quiet vehicle)
1972 Honda 600N
-its a car, stock, original
1998 4Runner
- gunmetal tundra rims, BABK
Gone:
1989 M3
1988 BMW 325i ( U-boat after hurricane-still runs)
1992 Galant VR-4 (never driven so sold it)
RacerX is offline   Reply With Quote
Old 04-12-2009, 03:15 AM   #3 (permalink)
heims all be it rare will wear out after time. simply undo the heim and check for wear. there should be no side to side play in it and although it should rotate and spin fairly freely there should be some resistance. but i would have to agree with racerx it is probably the inner.
RACER25 is offline   Reply With Quote
