sentra SE to nx brakes - SR20 Forum
Old 04-28-2009, 12:58 AM   #1 (permalink)
i have my running driving nx. and i picked up a sentra se and am in the prossessing of swapping everything sr into it. i looked and since i always get warned for bringing old posts back from the dead, i was wondering if you could inform me as to whether or not i can use the se spring and struts but the nx brakes and brake rotor?
help would be appreciated.
GoodEye2113 is offline   Reply With Quote
Old 04-28-2009, 10:33 AM   #2 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
A little confused by your post, but if you are putting the SR in a B13 Sentra SE, then yes you can keep the same struts and springs from the Sentra. The NX uses the same struts, but the springs are a higher rate. The brakes will also work, but if the car had drums in the rear, you will want to swap the master cylinder.
The community is here.
