Originally Posted by hiimrif
Ahh yes I have read you suspension post several times and if I remeber correctly you completely stripped your b13 to foam it(at least I think that was you).
So now my question is could you gain the same stiffness from a solid piece as from the tubular design. The reason for this question is simply that a solid brace would be cheaper to produce than a tubular one, and since my end goal is to make a small production run of these would it be more advantageous to be cheaper with approximately the same strength to allow more people the ability to get in on a set of braces.
Yes, that is me with the foaming-madness.
I *believe* my Classic has thee stiffest chassis, sans in-car bracing or seam welding, on Planet Earth.
I am not an expert on anything mechanical. I would *assume* that you could build equally stiff braces out of solid stock. As Hank pointed out, they would be heavier than hollow ones, but it still could not be that much weight, relatively speaking. The braces simply are not that large, maybe a couple extra pounds per side for solid braces vs. hollow braces (?).
However, I have no real experience or knowledge-base on metal fabrication. You'd have to ask Yahnoza (Custom Steel) or Chuck (Bolt In Bars) or one of the other "metal fabrication" wizards on our forum.
Props to you or anyone else that is producing performance parts for our vehicles.
Best of luck.
