Hi, I'm looking for some suspension dimensions because I own a Geo Storm and would like to see if I can make B13 struts work with my car using GC sleeves. If someone could provide me with the following dimensions, I'd greatly appreciate it.
I would like:
The distance between the two clevis tabs (where you bolt the strut to the knuckle)
The minimum and maximum distance between the two bolt holes on the clevis tab
The overall extended length of the strut
The distance between the studs on the strut tops (the studs that attach the strut top to the chassis)
Thanks!
