Mike, you do have to drill to mount the ST bar. On the trailing arm, there is a nut welded to the inside next to where the parking brake cable is bolted to. I think this is for the ABS sensor wire. The nut is closer to the rear of the beam. That is where the rear bolts for the sway bar go. After you have those, you push the car into position and mark for the front bolts. If you haven't already installed it, sell it and get the Stillen rear bar. It's adjustable, doesn't require drilling, and it a much better bar.
The community is here.
