??? Wilwood calipers and Tein pillowball mounts
Has anyone used the tein pillowball camber adjustable front mounts on a b13 using OEM lowering springs (hyperco gen 2 are what I have)? I dry fit one today on a koni yellow and there looked to be a larger gap between the stock spring perch and the top hat. Does that just preload the spring more? There also looked to be some play between the bushing for the top hat and the bottom of the pillow ball? Did you have to enlarge the hole in the fenderwall in order to use the adjustment at its full range? IS it safe to do that?
Thanks
