Originally Posted by wes
Honestly if you guys are going with AD22 fronts leave the rear's stock! The AD22 front and Maxima rear combo works OK, but depending on master cyl and PV choices the rears like to lock up first. This is a matter of preference but I was not a huge fan of that combo.
There is really no need to change MC unless you switch to the Wilwood front kit. Otherwise the Stock MC or NX MC are fine.
What pads were you running?
I thought it was GregV that said he used race pads up front and crappy pads in the rear ,and had great results.It seems like that sorta offsets the front to rear bias difference.
JDM NX2000 had the NX ronts,Max rears and NX master cyl from the factory,for whatever thats worth
