To b12 guys - SR20 Forum
Old 01-14-2010, 12:22 AM   #1 (permalink)
To b12 guys
hi i have a 1989 b12 and figured what type of suspension and strut bars i want to put on it along with the short throw shifter from pacesetter and just was woundering what type of sway bars work on these cars and where to get them by the way if you guys are interested about the shifter the company makes exhaust systems so you wont find it until the bottom of there page and any help would be much appriceated thanks
sr20detb12 is offline   Reply With Quote
Old 01-28-2010, 01:27 PM   #2 (permalink)
almost any B13 parts will work. the only places you'll find difficulty is the rear STB and rear sway bar. b12's have a different setup for the rear swaybar than b13's. instead, grab the swaybar fro a KN13 Pulsar SE (pulsar's with CA18 and CA16DE's).
as for STB's, there are both front and rear. Horsepowerfreaks.com sells the b12 cusco FSTB for the best price, and you can get the b12 rear STB from MyNismo.com.
as for front sway bars, there's whiteline, suspension techniques, and progress, as well as the option to using pulsar SE and b13 SER sways to upgrade. progress is the best aftermarket one, as it uses heim links to prevent binding, and is also quite a thick bar.
for LCA braces, theres the progress bar (3point) which is cheaper and effective, or the whiteline bar, which isn't much more expensive, is stronger (4 point), but on some cars there is a good chance of rubbing on speed bumps..
B12SportCoupe is offline   Reply With Quote
Old 01-29-2010, 12:07 PM   #3 (permalink)
alright thanks
Old 02-06-2010, 10:19 PM   #4 (permalink)
GMW
B12sportcoupe whats your set up you running ?
GMW is offline   Reply With Quote
Old 02-07-2010, 03:13 AM   #5 (permalink)
B13 KYB AGX's with Roadmagnets. sits a little too low for my tastes right now (scrapes on some speed bumps), but i'm on my 13" winters right now. when i get the 15's on in the next month we'll see how it goes.
i have a progress LCA brace that will be here in the next couple days, and will be getting the front sway bar as well. i have a sportcoupe, so it already comes with a rear sway bar thats almost the same as in the Pulsar SE so i won't be swapping out unless i can get them cheap.
Old 02-09-2010, 07:47 PM   #6 (permalink)
hey what kind of front bar sway bar did you have
Old 02-09-2010, 09:33 PM   #7 (permalink)
Turd Furgeson
Benito Malito's Avatar
Feedback Score: 41 reviews
Are they first gen road magnets? I've had both and the second run forward sat higher and worked great for me (in b13s). Could be the B12 though. I had a B12 w/ CA18DE when I lived overseas and I loved it when it wasn't blowing headgaskets.
1992 SuperBlack VVL SE-R
1994 P10 KL0
2004 Forester XT SGM
Old 02-10-2010, 01:08 AM   #8 (permalink)
currently runnign the stock one, which is again, better on a sport coupe than a regular B12 sway. very shortly i'll be running the B13 progress Sway bar. people have ran the B13 whiteline bar no problem on B12's. i'm using the progress because its better.
they're V2's. i'm pretty sure its the B12/wheels/tires (still on my 13" winters).
