Originally Posted by cabezaneo
well i replaced the axles and not even a block away the car started shaking bad. It shakes in the begining of second gear. Cv boot is also torn up. I replaced all my seals, ball joints, tie rods, bearings and also did an alignment and no good results. I;m so frustrated. Dont want to buy new axles and the crap is going to break again.
I had a very similar problem. On my passenge side shaft, every new cv shaft I put in, the center support bearing would blow apart after about 5 miles. O'Reilys was the only place in town that could even order them. It was like the bearings weren't even greased. They were sealed, so I couldn't check or grease them myself if I wanted to. Finally found a small foreign performance shop that could order ANY oem nissan part at a discount price.
