6 speed swap in a b13? - SR20 Forum
Old 03-15-2010, 12:49 AM   #1 (permalink)
sr20s are my crack
i see every so often that a person does a six speed swap. are they doing a swap from a QR and getting an adapter plate or some other kind of swap? and does it hold any kind of power? i know it might cost more than a b15/p11 swap, but it would be AWESOME to have another gear. any insight would be great. thanks
boosted b13- sold
1998 200sx se-r, cat back apexi n1, air filter, and nology hotwires. sold
srt4 swapped 98 neon sold
5spd p10 sold
94 XE-R GTiR- sold
searching for my next b13
trbob13 is offline   Reply With Quote
Old 03-15-2010, 10:54 AM   #2 (permalink)
Feedback Score: 5 reviews
mazworx sells complete kits...
They don't use an adapter plate, they swap the bellhousing. You need a donor car to do it easily.
I believe the newer 2004+ trannies are what you are looking for. There are a couple years that aren't optimal with the 6 speed.
Old 03-15-2010, 11:16 AM   #3 (permalink)
SR20DETERMINED
Feedback Score: 17 reviews
Take a look in mazworx section dude. This info is all over. Its a very easy swap usuing their kit with the p12 bell housing. I'm in the process of doing the swap with the 750 whp I'm shooting for. They are much stronger than the older transmissions. They say 600 plus whp holding capability for a long time. That big of a difference. And yes use the 04 and up trans. Better gearing.
92 Nissan Sentra SE-R
Fully built SR20DET, JWT S4 cams, 720cc injectors, Calum Basic ECU, Fidanza Flywheel, ACT extreem clutch, mezier electric water pump, Garrett t3t04 60 trim turbo w/ a .82 turbine housing, ebay tubular manifold, tial 38mm wastegate, All work done by me
ashtonsnissannx is offline   Reply With Quote
Old 03-15-2010, 08:39 PM   #4 (permalink)
Hostile Aberration
Shawn B's Avatar
Feedback Score: 10 reviews
Here for two (2) years and have not perused the Technical Information Library? How did you miss it?
http://www.sr20forum.com/driveline-t...-your-car.html
http://www.sr20forum.com/turbo/26047...os-inside.html
http://www.sr20-forum.com/mazworx/25...swap-kits.html
http://www.mazworx.com/index.php?l=product_list&c=269
http://www.sr20forum.com/new-members...rker-crew.html
Old 03-16-2010, 01:15 AM   #5 (permalink)
sr20s are my crack
[QUOTE=Shawn B;2514375]Here for two (2) years and have not perused the Technical Information Library? How did you miss it?
i know, i kind of searched but probably not enough. thank you for all the links though. i think this is gonna be my next upgrade.
