Steering Rack Slop - SR20 Forum
Old 04-04-2010, 08:48 PM   #1 (permalink)
Steering Rack Slop
Question about steering rack slop.
My steering feels sloppy through turns, but had no rattles over bumps, so I inspected all of the bushings and ball joints on the front suspension. None of them were bad, amazingly good for the age (136000 miles). But when I pulled and pushed on the steering rod, I heard a knocking noise. Using a screwdriver as a stethoscope I was able to hear the knocking from the steering rack. The knocking, I'm assuming is from slop. Should there be any slop in the steering rack? If so, how much is acceptable? and how would you measure that?
EvilLairSe-r is offline   Reply With Quote
Old 04-04-2010, 10:41 PM   #2 (permalink)
Feedback Score: 5 reviews
There are inner tie rod ends too inside the boots. That might be what you're hearing.
Old 04-04-2010, 11:38 PM   #3 (permalink)
I'll check that, thank you
Old 04-05-2010, 04:57 PM   #4 (permalink)
Hostile Aberration
Shawn B's Avatar
Feedback Score: 10 reviews
BTW, there are ES urethane steering rack bushings available.
Made my steering rack much more accurate and less sloppy.
Old 04-05-2010, 11:01 PM   #5 (permalink)
The bushings holding the rack are good, the rattle is withing the rack itself, or the intermediate rods adjacent to them. Should there be any slop at all?
Old 04-07-2010, 01:42 PM   #6 (permalink)
did you use the stethoscope with the car running? or have you done a power steering delete? power steering racks can have slop with the car off (ie. no power steering) while making clicking or knocking sounds, and thus the same can be said for a power rack that's had a power steering delete.
if everything's still copasetic, stetho the rack again with the car on. if you still have the clacking, replace it.
B12SportCoupe is offline   Reply With Quote
Old 04-07-2010, 03:52 PM   #7 (permalink)
Nope, I have not tried it with the car running. why would it matter if the car is on or not?
Old 04-08-2010, 01:24 AM   #8 (permalink)
it does. reason being is without the fluid being pressurized by the bump, there's room for play in the rack.
when i did a dry park check on my car initially with the car off, there was play in the rack. turned the car on and double checked and it was fine. which is good because i saved myself from buying a rack.
when was the last time the car had an alignment? and is the car lowered/how low? would be good to have it checked. my steering felt really sloppy when it needed one.
Old 04-08-2010, 11:37 PM   #9 (permalink)
That makes sense. I will try that on Sunday and see how it goes. Honestly, I havn't gotten the alignment done since I have bought it. I will get that done asap. Thank you for the advice
Old 04-08-2010, 11:53 PM   #10 (permalink)
if you've done suspension work, you'll need an alignment.
Old 04-08-2010, 11:58 PM   #11 (permalink)
Nothing has been done to the suspension, to my knowledge.
Old 04-08-2010, 11:59 PM   #12 (permalink)
ok, could still really need an alignment if its been a while.
Old 04-09-2010, 11:35 AM   #13 (permalink)
alright, will do that as well. Then hopefully the slop will be gone
Old 04-10-2010, 08:30 PM   #14 (permalink)
slave to the grind
TOOQIKK's Avatar
Feedback Score: 33 reviews
can you rebuild the racks?
my two front tires are goin in opposite directions!!!!happened after replacing the shackles and struts pulled on the shackle after hookin up the tie rod end to align the strut and the shackle.....???
car is off been off for while...wont be able to turn on no dash ,no interior right now....lol
94-XE 4D.... boost in the near future...stay tuned....
THE WEBSITE for all your synthetic oil and filter needs...AMSOIL First in Synthetics
Old 04-10-2010, 10:43 PM   #15 (permalink)
if you replaced suspension parts the car needs an alignment. if you did it yourself and found that the alignment didn't stick, it means that you missed a part that needs to be replaced. ie a ball joint, or tie rod end. only way to tell if a rack is pooched is to check for play in the rack with car turned on. if there is play in the rack, replace it.
