Brake systems conversions and equivalency questions
I have 96 b14 gxe. I want to upgrade the brakes to the ad22 set up and rear SE-R discs, but I understand there are other part of the brake system that need to be changed as well. I have utilized the search tool and haven't found solid info that indicates all of what needs to be changed on a gxe sentra braking system.
I currently have:
SE-R m/c
SE-R proportioning valve
SE-R rear beam with rear calipers and discs
AD22 brake setup with rotors
SS brake lines
Now my main question is, "what's left?" I feel that the brake booster may be the same as the SE-R but I would rather want to do this project only once. This car is non-ABS. I plan to change to maxima rear calipers later on, so any recommended changes to the setup i have would be appreciated. Thanks in advance guys.
