Coilover/Shock problems please help! - SR20 Forum
Old 05-06-2010, 10:37 PM   #1 (permalink)
Ok so first of all i ordered a set of coilover springs from ebay and a set of stock shocks as well, the problem is that im not sure how to set them up. if you look at this picture these are the questions that i have......
if any of you guys can help me i would appreciate it so much
RogerDodgerB13 is offline   Reply With Quote
Old 05-06-2010, 11:14 PM   #2 (permalink)
wants to go play
Blair's Avatar
Feedback Score: 5 reviews
http://www.sr20forum.com/technical-i...coilovers.html
91 NX2k hard top (track whore) Celebrating 14 years of ownership!
93 SE-R (street/track toy) Overkill is just about right
93 SE-R (daily driver) 221k and counting!
Old 05-07-2010, 12:29 AM   #3 (permalink)
Noobish..
Those coilovers do not look like they were designed for stock struts/shocks.
You can beat up your stock shocks all over the place but i don't reccomend it.
It looks like you would have very little shock travel afterwards and would be basically riding on your bumpstops..
Read that thread Blair posted. Hopefully you can send this stuff back... looks like a mistake to me.
1996 200SX SE-R 5speed, 220k, totally stock.
neptronix is offline   Reply With Quote
Old 05-10-2010, 04:24 AM   #4 (permalink)
OI!
Feedback Score: 11 reviews
All I have to ask is...WHY?
"It's not a question of where he grips it! It's a simple question of weight ratios! A five ounce bird could not carry a one pound coconut."
msamusick is offline   Reply With Quote
Old 05-10-2010, 10:05 AM   #5 (permalink)
Feedback Score: 31 reviews
You're gonna get a lot of grief on here over this... Reason is - this is not at all close to how it should be done... You will blow your struts almost immediately.. but to answer your questions..The coilover sleeve needs to come down all the way to the seat on the strut, you can use duct tape to wrap the strut to make the sleeve nice and tight on the strut. Then you use the rings to adjust the height of the vehicle. With coil overs the spring will be lose when car is up in the air (not like a conventional spring where you have to compress it). My advice is send the coil overs back and get your money back for those. If you have new set of stock struts - put your stock springs back on until you can get your hands on some AGX struts which pop up on this forum from time to time for an affordable price. Then you can get some nice GC coilovers - or others (not no branders) which also come up on this forum from time to time. Otherwise you will lose your money because these new struts will blow (not if but when and it will be soon) so you will be out for the struts and out for these coil overs... save your money, take your time and do it right.
The following link will tell you almost everything you need to know about our suspensions:
Good Luck
