advise on time attack/ road course set up on a hard top egg - Page 2 - SR20 Forum
Old 05-18-2010, 10:28 PM   #21 (permalink)
NX2000 Racer
Greg Amy's Avatar
Feedback Score: 9 reviews
Originally Posted by wes View Post
Are you referring to any of the 8610 inserts?
Can't say; I'm not familiar with "Spec V" inserts. But I can tell you that the technology of the 8611s and 8610s are about the same, are both "re-valvable", and that the 8610s also went to the "-RACE" part numbers at the same time...
Kakashi Racing
2006 ARRC/NARRC/NERCC, 2008 NARRC/NERCC ITA Champions!
1993 VE-Powered Electric Blue NX2000 (street rod)
Greg Amy is offline   Reply With Quote
Old 05-21-2010, 10:13 AM   #22 (permalink)
HAHAHA I was just about to put heim joints in to replace my tie rod ends... and that picture appears!
What size did you end up using... and did you modify a set of stock tie rod ends or build a complete piece.. I thing Im just going to Manichean a piece instead of messing with the stock part....
1990 pulsar GTiR RB. reving to 4k at 60MPH in 5th gear
I <3 85 to 95 JDM!
ZED_not_zee is offline   Reply With Quote
Old 05-21-2010, 03:29 PM   #23 (permalink)
Professor Dingbat
Feedback Score: 14 reviews
IT's a left handed heim joint, 5/8" I think (could be 1/2"), with a shoulder bolt. You can buy a shorter bolt than I did, I thought I would have to space it further down that I actually did, there's no good reason to have all those spacers below the rod end except that shoulder bolts are expensive. The spacers I bought from a circle track store. You need to make a female to female coupler that connects the stock tie rod to the left handed heim joint. You will have to cut the stock tie tod, so it's not an easily reversable mod.
The picture should tell you everything you need to know......except how to spell 'machine'
