Wheel Stud - SR20 Forum
Old 06-06-2010, 11:32 AM   #1 (permalink)
Wheel Stud
Hey guys, new member here, and yes I have used the search feature and to no avail. I have a 91 SER that I will be racing. We are required to run 1" lug nuts, and they cost like $5 a nut because of the SER's thread pitch. Was curious if anyone has a part number for standard pitch 1.5 instead of 1.25 lug studs that will fit these cars.
hebelracing1 is offline   Reply With Quote
Old 06-06-2010, 08:02 PM   #2 (permalink)
The Lil' SE-R Guy
Feedback Score: 6 reviews
I don't think you will find any the reason I say this is because of the knurling (I think) at the end of the stud that holds it in. I know it is hard enough to find extended studs that aren't Nismo ones that break frequently. A few people are running ARP studs for a WRX and they work well but share the 1.25 thread pitch.
JimmiSPEC
If you need any parts PM me!
SR24DEEP CT
Jimithin7000 is offline   Reply With Quote
Old 06-08-2010, 06:56 PM   #3 (permalink)
Did some research, found that 97 Mitsubish Eclipse lug studs are a suitable swap for the stock studs, only real difference I see is that the head of the stud, the part that rests against the back of the hub, is 0.8mm smaller, big deal or no?
Old 06-08-2010, 10:26 PM   #4 (permalink)
UPDATE, got new lug studs installed on one hub, they work awesome, perfect fit!!
Old 06-08-2010, 11:29 PM   #5 (permalink)
Which ones are the perfect fit? eclipse?
se-rajr is offline   Reply With Quote
Old 06-09-2010, 07:10 PM   #6 (permalink)
yes, the 97 eclipse studs are a perfect match
