CUSCO installation - SR20 Forum
Old 08-09-2010, 07:58 PM   #1 (permalink)
CUSCO installation
hi,
I just received a fstb Cusco, Fitment very good for my B14. accept there small tubing (pipe) at passenger side is on the way.
I am assuming I should remove this tubing first in order to install the fstb. and install this tube around the cusco fstb.
I have not check yet what tubing is that, it is to dark to look.
Anyone have better idea to install Cusco fstb?
anyone know what tube is it? thanks
fabadi is offline   Reply With Quote
Old 08-09-2010, 10:12 PM   #2 (permalink)
VE 96 SE-R
Feedback Score: 18 reviews
your talking about the powersteering hardline. you can just unbolt the bracket which will allow you to move it a bit to install your STB.
Robert Sousa
SR20DEEP CA
http://i17.photobucket.com/albums/b5...IMGP5288-2.jpg
96 SE-R VE goodness
95 G20, VE super stock DD
SER96VPEC is offline   Reply With Quote
Old 08-09-2010, 11:52 PM   #3 (permalink)
ok
so it is a powerstreering line.
I look aon a group buy and they have couple a picture, it seem the powerstreering line go around the one of leg of cusco stb
Old 08-10-2010, 12:14 AM   #4 (permalink)
VE 96 SE-R
can you post up one of the pics from the group buy?
Old 08-10-2010, 01:00 AM   #5 (permalink)
Are You VVL'n?
Feedback Score: 50 reviews
I believe you only use one of the 2 bolts of the p/s hardline to get around the bar.
JET
PARTING OUT: 96 CLOUD WHITE (QM1) SE-R - CLICK HERE
sr20jet is offline   Reply With Quote
Old 08-10-2010, 07:38 AM   #6 (permalink)
ok
I will try any possibility to make this think fit, any one else?
Old 08-10-2010, 01:42 PM   #7 (permalink)
Are You VVL'n?
Where the p/s hardline bracket is already set, just move it towards the firewall to the next hole (the 2 set holes for the bracket). Put in the strut bar and then bolt down the bracket with one bolt and you should be done.
Old 08-19-2010, 10:51 AM   #8 (permalink)
Hostile Aberration
Shawn B's Avatar
Feedback Score: 10 reviews
Yeah, it's in there. Including a link, which leads to a thread, with more links in the second post.
Which answers all your questions. With pictures included.
http://www.sr20forum.com/driveline-t...ml#post1651584
