Ive tried everything else I can think of.
Im starting to believe its a bad strut (agx)
It happens under hard acceleration or when going fast (60+) and taking hard turns (slalom) but its when im turning left. The vibrations arent so noticeable when turning to the right at high speed, just left.
Ideas?
...Currently down due to a clutch disc spring failure....
either I replace all the control arms and bushings
or the struts....
anyone have a clue?
i just replaced control arms bushings tie rod outer wheel bearing right,my vibration is on the right like +70 my inner tie rod s are bad going to replace did outer i think it my be my inner i hope but will do (motor mounts) -i heard it might be that) then axel, like at 60-70 it vibrates like crazy on right hand side,some guys on forum said bearing replaced yesterday same sh*t
im going to replace inner tie rods on weekend,then motor mounts polys i have to order then(inserts) then struts and mabe axel if i still have the problem i'll keep you posted .by the time im finished i should not have that problem i hope ..good luck on yours
just did my inner tie rods vibration above 70mph its still there going to do my motor mounts next????? how did you make out did it stop??
I havent been able to do anything to it, for the last week its been in the shop for upgrades and dyno tuning.
After I get it back this week, im doing:
wheel bearings (all)
front control arms (comes with ball joints)
front sway bar links/bushings
inner tie rods
outer tie rods
Originally Posted by si-r_to_se-r
what about the tires
the new tires did solve part of my vibration problem. The old tires had flat spots from sitting 9 months while i was gone overseas.
...I didnt spect to say this but...its your car crached? couse when the chasis get bend by some sort of colission ita can hapen that it bend and so your car go slightly to one side (left or rifht)
...I hope Im wrong man
Hey man.Before my 2nd nx was totaled i had a bad axle that would turn in the transmission without turning the wheel sometimes.The boots weren't busted and the wheel bearing was fine.The bearings in the axle itself were bad on the wheel end of the axle.That vibrated while turning too until i replaced the axle.The new one did fine.I hate to say it,but it's either that or your transmission is to blame.Our xe transmission sounds horrible under hard acceleration in a straight line or while turning.
Forget graceland,i wanna go to Sugarland.Jennifer Nettles can stay with me ANYTIME.
