brake master cylinder questions - SR20 Forum
Old 11-15-2011, 02:35 PM   #1 (permalink)
I have a JDM Nissan Sunny to which i have upgrade the front brakes to AD22VF and looking to do the rear disc conversion soon
The car come with a 3/4 Master cylinder which is not adequate i want to do the 15/16 but have a little concern my model uses the 4 pipe Master and proportional valves and i got a 2 pipe 15/16 Master from a friend can it work
don't know how i would work out the proportion
current master
propose master
The Harder They Come The Faster They FALL
Nissan is King is offline   Reply With Quote
Old 11-15-2011, 03:52 PM   #2 (permalink)
I think the proposed MC is for a brake system equipped with ABS. Does your current setup have ABS? Do you know if your buddy took his MC off a car with ABS?
DrunkenMonkey is offline   Reply With Quote
Old 11-15-2011, 11:37 PM   #3 (permalink)
Actually came from a vehicle without ABS a Nissan pickup
My current setup doesn't have ABS
Old 11-16-2011, 09:27 AM   #4 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
You will need a different master cylinder. The trucks had the proportioning valve external.
The community is here.
Old 11-19-2011, 04:46 PM   #5 (permalink)
You can ether remove all the lines for your car and install lines from a car with 15/16 cylinder or some JDM N15 Pulsars (i think the awd version) have a four port 15/16 cylinder.
pTen is offline   Reply With Quote
