ADV22 BRAKE QUESTION? - SR20 Forum
Old 01-20-2012, 10:57 AM   #1 (permalink)
I recently went to the salvage yard and got the brake's off a 92 NX2000, front calipers and rotors, rear calipers, as well as the M/C all from the same car. The only problem is that the M/C is for ABS car. My question is, will the brake bias change if i use the M/C from the B13 SE-R? I know that the ABS version NX has the bigger REAR rotors, so will the SE-R M/C work if the brake proportions are equal: bigger fronts and bigger rears
btsr22DET is offline   Reply With Quote
Old 01-29-2012, 02:34 AM   #2 (permalink)
AKA-- JJKAMIKAZE
Feedback Score: 8 reviews
it will be fine. I use a b13 master cylinder with nx brakes on all my sentras, I just run higher friction pads on the front than on the back when at the track.
NismoTheDog is offline   Reply With Quote
