NX2000 RACK AND PINION??? - SR20 Forum
Old 01-17-2013, 04:04 PM   #1 (permalink)
what is a good rack and pinion that is manual and not power steering?
SR20DET/NX2000 is offline   Reply With Quote
Old 01-18-2013, 08:27 PM   #2 (permalink)
Shift_2.0
Feedback Score: 49 reviews
As far as I know the 'E' model B13 sentra is the only manual rack that is direct bolt in for the nx2000. Make sure you get the u-joint for the steering shaft too,you need that for it to work.
[QUOTE=classicaddict;1807101]ebay coilovers are about the same as using dooky as brake pads
eggman is offline   Reply With Quote
Old 01-20-2013, 11:19 AM   #3 (permalink)
Careful, someone has said you will lose your quick steering ratio.
motoman is offline   Reply With Quote
Old 01-21-2013, 08:31 PM   #4 (permalink)
Shift_2.0
True.The manual rack is more turns "lock-to-lock"
Most guys just loop the power steering lines and keep the power rack for this reason.
I have tried/driven them all.....I will keep my power steering,Thanks.
