I've been pressed for time so I hired a mechanic friend of a mechanic friend to pull the bad engine, he didn't label anything, then moved a few days later. So... I've been playing "where does this nut, bolt and wire go" as I put the JDM replacement motor in the engine bay. I'm on the home stretch but I'm a little stumped with one of the wires that is part of the bundle that comes from by the fuse box on the pass. side. There are four wire connections: One small ground wire to Alt, one large ground wire to Alt, one large plug into the Alt, and the last one is a small oval shaped electrical connector that clips into something but can't figure out what. Any ideas?
