so i just made this just in case it could ever help out someone else when they install there bars, theres not much on the fourm about installing them and i had free time LOL
each box came with a junk load of bolts and washers so when i found out from them the correct way to assy them i took a photo of it lined up with how it would go together on the rear:
This is a close up view of when i assy a rear link:
This is a shot to show u all the hard ware for the rear LOL:
Theses bolts go on the U brackets where the poly bushing go into:
Now for the front its allmost the same heres some info faxed to me from progress:
and heres the front laid out:
And here the end link for the front assy:
And the u brackets for the front:
Now for the install pics, ill start with the rear i used a lift when i had it done but in case u dont have one be safe when useing jackstands. and lube the bushings up good and the end link bolt that connects to the sway bar.
OEM rear bar with ES bushings drivers side, note how the u bracket with the poly bushing is on the rear side of the mount, the progress bar will mount on the drivers side on the front side of the bracket:
Heres a pic of the rear progress bar assy:
Rear OEM compaired to progress bar:
This is the passenger rear U bracket installed, note theres replacement bolts that come with the bars and i replaced the old ones i got in this photo right after i took this shot, the difference with the RT from the left is the Nuts are welded on the rear, so progress supplys 2 new bolts for the RT side only, for the left side they supply 2 bolts and 2 nuts LOL:
welded nuts
