Old 12-05-2006, 11:41 PM   #1 (permalink)
The DET is in!
Trader Rating: 17 (100%)
Another Tire Thread
Okay, so Christmas is coming up, and I just got my DET in so basically I have no traction on my LE steelies and economy tires lol.
I will be daily driving, at the strip a couple times, maybe 1 auto-x a month. The tires need to grip like mad, have a high speed rating, do well when it rains, and not wear out very fast. I have stock B13 SE-R wheels sitting in my garage so I will use those.
Price isn't much concern.
Thanks a ton everyone!
W11 Avenir
GTi-R T28 Setup
Greddy Type S BOV
FMIC
Calum Realtime
Z32 MAF
Subaru 520cc Injectors
O2 Induction Style Manifold
Autometer: Water, Oil, Boost
3.5" Front Bumper Side Exit Exhaust
Progress Coilovers
Walbro 255lph
Nismo AFPR
ACT Xtreme Clutch
Prothane Motor Mount Inserts
RedDragun is offline   Reply With Quote
Old 12-06-2006, 01:06 AM   #2 (permalink)
Seeing red
JimR's Avatar
You're not going to find a tire you described in a size that fits 14x5.5" wheels.
The Falken Ziex 512 doesn't do any one thing particularly well, but it does about everything you could want for cheap in 185/60-14. It's the only tire that I've used both at an autocross (fun run only) and on snow, and not loathed it.
Maybe Yokohama ES100 if you never, ever use them below freezing.
Better yet, upgrade to bigger wheels. DET swap before wheels and tires?
1992 SE-R / 1993.5 G20
JimR is offline   Reply With Quote
Old 12-06-2006, 08:57 AM   #3 (permalink)
employed again
Azenis 615s, 195/60/14
Matt
MaddMatt is offline   Reply With Quote
Old 12-06-2006, 09:57 AM   #4 (permalink)
The DET is in!
I really can't afford new wheels right now, and honestly I didn't think about it when putting in the DET lol.
MaddMatt, will those do well in everything I subscribed?
Old 12-06-2006, 10:10 AM   #5 (permalink)
employed again
615s are essentially the tire of choice for STS/STX/STS2 autocrossing. So, yeah.
They should have at least an H (130mph) if not a V(149mph) rating
615s do fine in the rain. Don't even think about drivcing in the snow with them though.
May be asking for a bit much here. With daily driving, autocross and dragstip sessions, I'd expect to go through a set a year.
Old 12-06-2006, 10:22 AM   #6 (permalink)
Drinking The H Juice Now
BigB's Avatar
Grip and long life are mutually exclusive.
Grip, by it's nature, is a function of wear. Grippy tires do not last very long.
You are asking for the "perfect tire" and it does not exist.
We know what you WANT the tire do, now.
What do you NEED the tire to do? $$, grip, longevity, wet performance. You need to rank those in terms of need and then figure out what tire you want.
1992 SE-R WHT - SOLD
1992 SE-R BLK - R.I.P.
2001 -Mazda MP3 #60 of 1500
1991 Integra LS -
BigB is offline   Reply With Quote
Old 12-06-2006, 11:49 AM   #7 (permalink)
Is an SE-R/VE a VE-R?
BigB, as usual, nails the oxymorons. You will get an opinion from each of a bazillion folks and thus have a bazillion different opinions - BUT - Matt & Brian are two of the most knowledgeable in this domain. I looked for the 'perfect' street tire and after MONTHS of research chose B'stone RE950s but NOT on tiny little rims. Neither Brian nor Matt would like 'em - I'll get maybe 25-30k out of them; they're kinda slick until hot (but it's fun to spin the tires when the VE cams switch), they're tolerable in rain, worthless in snow. Ask Brian - they're like skate wheels in an autox :-). I'll be listening very carefully to Brian and Matt and a few others when these are gone, but I will edge in the direction of a tad more than the 5,000 miles one gets from the super gooeys.
Jer
'93 B13, etc.
do it over and over again?
Old 12-06-2006, 01:44 PM   #8 (permalink)
Her 1st track day in 2017
Fosters's Avatar
Trader Rating: 41 (100%)
I doubt the Azenis would be a good fit for him, once he lists his needs. I think JimR got the closest w/ the 512's. We run those on my wife's car (2nd set), and they are satisfactory.
.....have a high speed rating.....
The speed rating isn't going to do much for you. Does it matter if they are rated for 135 or 150 mph when your trap speed is (maybe) 100 mph, or if you top out in 3rd gear (maybe 2nd?) on the auto-x course? Your putting too much stock in that letter.
I'm willing to bet that that $50 each 512's are easier to buy (or con someone into buying) than $130 each S03's, etc.
'95 G20 - daily driver
'92 NX2000 - Money Pit
Izzy's Cages---------------Custom Steel---------------G Spec
Old 12-06-2006, 01:59 PM   #9 (permalink)
Canyon_Boogie
Trader Rating: 57 (100%)
I love my 615's on my DET. I run at 9psi.... but have never driven it in the rain so couldnt help you there.
Be polite, be professional, have a plan to kill everyone you meet.
~KnuckleDuster~ is offline   Reply With Quote
Old 12-06-2006, 06:30 PM   #10 (permalink)
KD, it doesn't RAIN over there :-). How many miles do you expect the 615's to last at NINE psi?!! I take it you're going in a straight line?
Fosters is right - the speed ratings are for SUSTAINED speed anyway - heat survival. Unless you're doing track work, NONE of us gets up there and stays up there - certainly not on the right coast - you guys in the middle or on the left coast with some space around you might get to play some - - -
Old 12-06-2006, 10:46 PM   #11 (permalink)
I have 615's, i have done a couple auto-x's two track events (half of one in the wet) and daily drive it. I can hardly notice any wear. They do unexpectedly well in the wet, and don't cost an arm per tire. I think these tire would be perfect for what your asking.
1993 Nissan Sentra SE-R
DerekBaker is offline   Reply With Quote
Old 12-06-2006, 10:55 PM   #12 (permalink)
Seeing red
JimR's Avatar
I'm thinking cheap all-seasons on the stock wheels, then saving for a second set of 15" wheels with Azenis/MX/Z212/etc. for "fun" weekends.
Old 12-06-2006, 11:33 PM   #13 (permalink)
The DET is in!
Yeah, I was thinking the 512's before DET. Only thing is that they don't make the sticky 512's for 14" wheels.
Old 12-07-2006, 12:33 AM   #14 (permalink)
Jacked on the Juice
happynole's Avatar
Trader Rating: 78 (100%)
They don't make "sticky" 512's at all. That being said, I had 512's in 195/60-14 on stock se-r wheels for about 2 years and had no complaints..........until I picked up a set of used Azenis 215's for this last summer. Big difference. And then I bought 195/50-15 Pole Position S03's for the Hock R's I bought towards the end of summer. Big difference some more. So I guess the old adage holds true in this case, you really do get what you pay for.
Ruby Red 91 NX2000....Kimme in the Driver's Seat
White 93 SE-R......what can I say, this is taking forever
Slate Grey 93 NX2000.....Automatic Daily Driver
Life is a Journey, Enjoy the Ride
http://www.datsun.org/roadster/liter.../dream_grg.mov
happynole is offline   Reply With Quote
Old 12-07-2006, 12:55 AM   #15 (permalink)
The DET is in!
Well there are 2 compounds for the 512's. One has about twice the tread warranty as the other lol. The 30-55 series are 30,000 mile rated, and the 60-65 series are 60,000 mile rated.
Tires would only have to last a year or so. Would the RT615's last that long? What size should I go with?
Edit:
I guess 195/60R-14 86H is all there is.
Old 12-07-2006, 01:52 PM   #16 (permalink)
Technician and Enthusiast
I have the perfect tire for you. The Potenza RE750. Grips like crazy in the rain, lasts a long long time, and has cornering response that is truly amazing. I have had the Azenis 615 and it sucked in the rain. I had BFG G-Force and I like the potenza RE750 a lot better. The perfect all around tire for me.
Coheed is offline   Reply With Quote
Old 12-07-2006, 02:38 PM   #17 (permalink)
The DET is in!
Well looking at those ratings on tire rack, it seems the Potenza's wont do too well in the cold. Right now it is 23* outside. I don't really drive the car in the snow, but it does need to function in the cold.
Will the 195/60R14's fit on stock SE-R wheels (14") and not rub?
Old 12-07-2006, 02:43 PM   #18 (permalink)
Fosters's Avatar
Tirerack doesn't list a 14" tire for the RE750. What I found: Click
Old 12-07-2006, 02:43 PM   #19 (permalink)
BigB's Avatar
Then you need all season tires.
M+S tires. Which means you are going to sacrifice grip for cold weather use.
This is good as these tires are usually cheaper than UHP tires.
Old 12-07-2006, 02:47 PM   #20 (permalink)
Seeing red
JimR's Avatar
Edit:
If that's your only car, you don't want that tire for a year of street use. Don't let anyone tell you that is a sane choice for a four-season daily driver.
Get stock-sized all-seasons for your stock wheels, then save up for better wheels and tires for autocross/summer/drags.
I would buy 185/60-14 Falken 512's, then look for a cheap set of 15-inch alloys while I'm saving money for 205/50-15 Azenis. Do it that way, and you can have it both ways.
