Well, I got the JDM motor running pretty good. I have a Stillen POP charger, intake pipe, SSAC header, 2.5'' cat, 2.5'' cat back. Now, the car seems to not pull as hard as it used to. I don't know what could be causing this. I know I have an exhaust leak where I have a sh*tty weld near my cat. It is barely holding on and leaks bad. Could this be the source of the hesitation. It seems to pull strong until 4,500. After that it feels like 500 pounds just hit my trunk. Now, I tried out my car to see if the gas light works and it got so low to the point where it is now on. Could the bad gas and 17* timing be the issue? I can't think what the issue is. I'll have to try new plugs.
