So I hit some black ice tonight and curb checked the front right wheel. Wheel is obviously bent and I have about and inch or so of toe out. The wheel seems to have hit the curb parallel [left turn+understeer].
My question is, what is the first thing to bend?
Im thining LCA becuase its the loest part of the suspension, but also maybe the strut?
Any ideas? I am goign to get it off the ground tomorrow after work and check it out.
This happened aroudnt his time last eyar to me too, with in 20 feet, but it was my honda, and I had to replace prac tically everything in the weel well.
E36 BMW 325is
P10 Infiniti G20
2009 Aprilia SR50 R Factory
LCA, strut. inner & outer tie rod.
All could be bent.
i actually got run off the road not too long ago. i hit a curb head on and flattened the front and rear tires and messed both rims up. fortunately, the only thing that got messed up was the strut. check that and the control arm. my brother bent his when he hit a curb. then the tir rods.
-Sam
91 White Se-r|I/H/E/nx2k brakes/eibachs/gr-2s/soon gti-r powered|14.5@94
92 Slate Grey Se-r|bone stock/100k/Zero Rust
94.5 Aztec Red Se-r|SSAC header/Megan Catback/JWT ECU/Hyperco springs/AGXs/ST f/r sways/ST bushings/Stillen FSTB/nx2k brakes/SE-Ls with 615s/VE POWERED
94 Blue G20T|mint interior/80k/zero rust/ve soon
93 Dakota|250k and counting/5 speed/studded tires/winter beater
Well i got it up in the air, the inner tie rods are rusted pretty bad, so i cant move the jam nut much. Im thinking it may be time for a XE manual rack. Pretty sure the LCA is bent, and it looks as if I may be force to just go ahead and doo my GC/AGX setup early....
I bought my car wrecked, the old lady hit an embankment around a turn. It had a bent tie rod and a bent A-arm. I bought a new A-arm from a junk yard for 30$ and heated the tie rod up and bent it back in to shape
I have a new LCA and still waiting on a new ball joint. Put a new inner tie rod on and got it up o spec for tow [~1/16] in. Threw a cam bolt on there to eye up camber temporarily. Waiting to fix a situation with some struts I bought on here.
