Old 12-12-2006, 04:54 AM   #1 (permalink)
ice
Nochnoi Dozor
Neuspeed?
Does anyone know what springs are yellow? i heard they might be neuspeed...can anyone verify this?
Sleeper: Its what made the Trojan Horse so popular back in the day.
92 Se-r
ice is offline   Reply With Quote
Old 12-12-2006, 10:01 AM   #2 (permalink)
Travieso Racing
dropzone are also yellow... if they are neuspeeds they should be yellow with red neuspeed lettering on it
Danny GDM (HKS)
1993 PRiMERA GT
Old 12-12-2006, 01:45 PM   #3 (permalink)
Lincoln Tech Grad
i thought dropzones were red...anyways yes neuspeeds race springs are yellow
www.myspace.com/speedracer914
92 se-r (project spraypaint) - under construction
http://s56.photobucket.com/albums/g1...14/The%20Whip/
Mods:courtest fstb, progress adjustable rsb, place racing cai, pacesetter headers, hyperco gen 2 (to be installed), gti-r turbo manifold (to be installed)
hazardous is offline   Reply With Quote
Old 12-12-2006, 03:10 PM   #4 (permalink)
ice
Nochnoi Dozor
my old ones were red dropzones...but ill check these for any lettering in them
Old 12-12-2006, 09:46 PM   #5 (permalink)
Use to be ^
Neuspeed made products for our sentras?
*1991 SE-R TURBO SOLD!!!
*1990 240sx coupe SOLD!!!
*1991 SE-R SOLD!!!
*1996 Toyota Tacoma X-cab 2wd
*1991 Infiniti G20
*1989 240sx coupe
sentraturbo is offline   Reply With Quote
Old 12-12-2006, 09:58 PM   #6 (permalink)
Lincoln Tech Grad
not that i know of... they only make stuff for honda/acura and volkswagen/audi if i'm correct
Old 12-12-2006, 10:36 PM   #7 (permalink)
Hostile Aberration
Shawn B's Avatar
Ditto. Not that I'm aware of.
Old 12-13-2006, 02:01 AM   #8 (permalink)
ice
Nochnoi Dozor
well my friend has yellow springs but i have no idea what they are...anyone have a clue?
Old 12-13-2006, 02:13 AM   #9 (permalink)
this foreum= FAIL
most likely ebay specials
Old 12-13-2006, 03:30 PM   #10 (permalink)
ice
Nochnoi Dozor
ehh whatever...springs are springs
Old 12-13-2006, 03:46 PM   #11 (permalink)
i love b13's !
Trader Rating: 22 (100%)
^ i wouldnt go that far.
stratton.
im back.......
Old 12-13-2006, 09:16 PM   #12 (permalink)
Lincoln Tech Grad
Old 12-13-2006, 09:20 PM   #13 (permalink)
SR20DEbT
Trader Rating: 53 (100%)
Your struts won't be saying that after they get very weak due to an aggressive drop of like 2''. Don't get me wrong though, I have H&R springs with GR-2 struts but I got them because they came my way very cheap and I wanted the "look". I can't compete with the proper B13 setups though.
-Bes
92 Sentra GTi-R
Small Snail Crew
----BNB----
Old 12-13-2006, 09:38 PM   #14 (permalink)
IF they are yellow they may be Aerospeed springs. They are flat out garbage if so.
-Rob-
Get ready for a big SE-Rprise
Old 12-13-2006, 11:22 PM   #15 (permalink)
ice
Nochnoi Dozor
well he said there stiff and handle pretty well but how much you think struts will run me? im getting the springs for $30 BTW
oh and are aerospeed springs bouncy? and if i get good struts wil they still be bouncy?
Old 12-14-2006, 12:56 AM   #16 (permalink)
this foreum= FAIL
your question is packed with ignorance................and please dont take offence to that lol i ment no harm.
ill let you in on some info. stiff is not always good.....you could have a ride like a caddy and if its set up properly it will out handle all. bouncyness comes from the springs being to stiff and the shocks not being able to do their job. one of the best and cheapest handling setups you can do in get a set of hyperco springs and agx struts paired with a good rear sway bar. this setup will only drop your car 1 inch but thats perfect. the preblem with b13's is they have very little suspension travle, so if you drop it any farther than one inch it only has about 1.5 inches left till it hits the bump stops (once that happens your tires are "shocked" and will loose traction/start sliping)
another thing many people dont think about is if you have very stiff/low springs and dont have the suspension travle or proper shocks to handle them you will get even more body roll than stock! think about it, you have "performance" springs about 30/50% stiffer than stock on near stock shocks. in a corner the inside of the car looses weight then the springs have less weight sitting on them and they lift the car causing body roll. now if your springs are stiffer they are pushing up harder on the car and if the car is sitting 2 inches lower it will come up 2 inches higher during body roll.......thats no good! so please save up your money and sped it correctly. i can tell you from experiance you will deffinatly not be dissapointed if you buy a good setup.
Old 12-14-2006, 03:34 AM   #17 (permalink)
ice
Nochnoi Dozor
well i dont have the money to spend on a set up like that but i get what your saying and i would love to be able to just go get the best damn set up money can buy. But i just want my car to drop a tiny bit and i want it to handle better than stock sicne my old b13 had nothing but dropzone springs and it handled waaaay better than this b13 BUT it would bottom out on any speed bump and railroad track
Old 12-17-2006, 08:56 PM   #18 (permalink)
Lincoln Tech Grad
well as far as struts go your best bet might be some agx which go for about $430 shipped on ebay
Old 12-17-2006, 09:10 PM   #19 (permalink)
The Genesis
IIRC aerospeed sold sleve type coilovers(like ground controls). I havent heard of them for a while, which is a good thing. Only other yellow springs that i know of for nissans are goldline, but iirc, they didnt make any for the b13.
Old 12-17-2006, 09:50 PM   #20 (permalink)
build completed...
Trader Rating: 26 (100%)
Save up your money and do it right, or don't do it at all
SR20DEEP in TX
