Old 02-11-2007, 10:50 PM   #1 (permalink)
Shift_日産
Question about collision repair.
Sup guys.
I have a 91 SE-R. Well 2 years ago i wrecked it. Hit a pole @25ish mph.
Here is what it needs
Radiator support
front hood
front bumper
grill
bumper filler
nissan emblem
Car might need to be hooked up to a pullers to make sure its straight. Car has some rust damage around the rear wheel, rocker panel, (and what worries me) the pass side wheelwell. Car has a lot of dings and its multi colored. car is gonna need new speedo, axles, breaks, motormounts, & tires.
Is this car even gonna be worth fixing. If so can it be done for under $1,100? I paid 1,100 for it 3 years ogo but after i wrecked it i parked it.
Opinions welcome
Thanks
1996 Nissan 200SX SE-R
クリストファー
•AT-MT B13-LSD swap •JWT P/P •2000SE Clutch Disc •Cusco FSTB •Hyperco Gen2 •Unorthodox 4 Pulley Set •HP Racing Header •Rota 16x7 Circuit 8 w/ BFGs •12Lbs.Flywheel •Injen CAI •Stillen POP Charger •B&M Short Shifter •91 Cam •Prothane Mounts •Magnaflow Muffler •Taylor 10mm Wires •Carbon Fiber Hood •Erebuni Body Kit •Black Healights w/ Amber corners •Redline MT90
AztekSE-R is offline   Reply With Quote
Old 02-11-2007, 11:00 PM   #2 (permalink)
Lincoln Tech Grad
I think as far as fixing the body damages that yes, it is possible to be done for under $1,100. Keep an eye in the classified section for b13 part-outs. That would be the best best. You can also find the speedo, axles, brake, mounts, and tires in the classifieds. The body work, paint, and rust is another story. Good luck and keep us posted.
www.myspace.com/speedracer914
92 se-r (project spraypaint) - under construction
http://s56.photobucket.com/albums/g1...14/The%20Whip/
Mods:courtest fstb, progress adjustable rsb, place racing cai, pacesetter headers, hyperco gen 2 (to be installed), gti-r turbo manifold (to be installed)
hazardous is offline   Reply With Quote
Old 02-19-2007, 05:50 AM   #3 (permalink)
You need a professional help for your wrecked car. Check out some sites to have a quote for your car needs.
_________________________
Ron Davis Aluminum Radiators - Download the Custom Aluminum Radiators by Ron Davis Racing Products
life_radiator is offline   Reply With Quote
