Originally Posted by JimR
Yep.
The shifter arm disconnected somewhere. The prime suspect is the vertical bolt that connects the shifter arm to the bracket on the back of the transmission. One time I found the nut was loose on my car.
Thanks for the quick response! Would this be considered a big problem, because i need my car asap. By the way is this bolt hard to find?
Maybe that bolt was not tightened up when i changed my clutch couple weeks back.
