Old 02-15-2007, 10:19 PM   #1 (permalink)
Trader Rating: 38 (93%)
classic turns off everytime i stop
guys i need help my car turns off everytime i stop what could it be please help
99sel-r is offline   Reply With Quote
Old 02-15-2007, 10:20 PM   #2 (permalink)
XxToKeSxX's Avatar
idle speed might be too low
is it only when its cold? edit: scratch that - san diego
1998 200sx SE-R | SR20DE
1991 NX-TuRBO | SR20DET
1995 240sx BaSe | ____DET
Shift_Buy Broken & Build...
Old 02-15-2007, 10:50 PM   #3 (permalink)
Lincoln Tech Grad
maybe a vacuum leak???
www.myspace.com/speedracer914
92 se-r (project spraypaint) - under construction
http://s56.photobucket.com/albums/g1...14/The%20Whip/
Mods:courtest fstb, progress adjustable rsb, place racing cai, pacesetter headers, hyperco gen 2 (to be installed), gti-r turbo manifold (to be installed)
hazardous is offline   Reply With Quote
Old 02-16-2007, 01:36 AM   #4 (permalink)
all vacum lines are hook up it doesnt do it all the time i think every 2 out of 10 stops and it turns on fine and everything it only turns off everytime the idle goes below o rpm
Old 02-16-2007, 01:39 AM   #5 (permalink)
how do i adjust the idle
Old 02-16-2007, 01:59 AM   #6 (permalink)
Empire-CAT Machinery Tech
i had the same problem.. my idle was too low, then fixed it, then idle was rough at cold, and alittle at normal temp., turned out my TPS was bad, it was giving out wrong signals causing rough idle...u might wanna check that....
2005 Infinity G35 Sedan 6M
2005 Nissan Titan SE 2X4 my DD
1991 clean white SE-R -Bone stock- another DD (second owner)
[b]91 Mint SE-R (third owner)
Mods: Black, Very Clean, Turbo. -weekend warrior-
SE-Riouse_93 is offline   Reply With Quote
Old 02-16-2007, 02:24 AM   #7 (permalink)
sorry to sound stupid but what does tps stand for throtle p? sensor ?
Old 02-16-2007, 02:37 AM   #8 (permalink)
Travieso Racing
throttle position sensor
Danny GDM (HKS)
1993 PRiMERA GT
Old 02-16-2007, 02:43 AM   #9 (permalink)
so it might have went out is that what it is or its just not connected right ?
Old 02-16-2007, 02:48 AM   #10 (permalink)
first fix your ide.. turn off car. unplug your tps, adjust idle screw on the above AAC valve youll see it its a big ass screw next to your p.s pump, then when u fix it, shut off car, connect your tps, and if rough idle continues, check you tps Voltage...
no if your tps whent bad your throttle responce will be like sh*t...your tps works, but its going bad, and its just sendin out erratic signals to your ecu causing poor idle... check your voltage on your tps with a voltmeter.i forgot what the normal voltage has to on the tps..so ill get back with ya on that...
Old 02-16-2007, 02:58 AM   #11 (permalink)
oh and i forgot to say...the whay youll tell if its bad when u unplug the tps and turn it on and idle issnt rough and is good, then when u plug in the tps and idle is acting up.. its totally your tps.. thats how i discovered my problem...
Old 02-16-2007, 03:59 AM   #12 (permalink)
Nissan Technician
Trader Rating: 17 (100%)
Clean your TB
Ryan
<<< Mine
SE-R_TECH is offline   Reply With Quote
Old 02-16-2007, 07:38 AM   #13 (permalink)
banned
I had the same problem about ˝ years ago… It was broken oxygen sensor. The car kept turning off while shifting and idling but it was drivable if you use throttle while shifting.
You can adjust the throttle position on the engine with a screwdriver to increase idle speed if you want.
FANTASY is offline   Reply With Quote
Old 02-16-2007, 11:16 AM   #14 (permalink)
Don't stop.
'93 SE-R - VE Powered
'02 G20 Sport - Slow but comfy
http://www.cardomain.com/ride/102760
Dan_93SER is offline   Reply With Quote
Old 02-16-2007, 11:24 AM   #15 (permalink)
Originally Posted by Dan_93SER View Post
Don't stop.
^^^^^^ that would be a good ideah
Old 02-16-2007, 01:38 PM   #16 (permalink)
my car seems to have the same problem. only sometimes the engine would cut off when i roll on neutral to the stop light or stop sign. its not really a big hazzard to the vehicle is it?
ATL_b13 is offline   Reply With Quote
Old 02-16-2007, 03:08 PM   #17 (permalink)
^^^^ yes it would definitley be a big hazard to your vehicle and the one in front of you, '*** you won't have brakes.
93b13gtir is offline   Reply With Quote
Old 02-17-2007, 12:21 AM   #18 (permalink)
this just happend after i install my cai so to adjust the idle i have to unplug the tps and adjust the screw and then turn on the car ?
Old 02-19-2007, 08:06 PM   #19 (permalink)
all motor
you might also want to clean the terminals on the battery and make sure you have a good ground.
Classic SE-R is offline   Reply With Quote
Old 02-19-2007, 08:23 PM   #20 (permalink)
i adjust it the idle control valve and it seems that helped my car i hasnt turn off since then but its seems like its breathing a lot of air you can even hear it i dont know if thats safe or i adjusted it more than enough
