Closed Thread
Old 02-16-2007, 01:15 PM   #1 (permalink)
banned
Which wheels should I get?
My front end is 1.2'' lowered with Eibach springs and rear end is stock.
I want to buy wite rota wheels (16 x 8.0 +20 4h x 100) from here http://www.rotawheels.com/slipstream.php
but I am suspicious whether I can use +20 offset?
I will probably go with yokohama prada 205/40/16 tires.
do you think that 17s with 215/35/17 tires look better on b13?
FANTASY is offline
Old 02-16-2007, 01:21 PM   #2 (permalink)
SR powered S13 coupe
McCoy's Avatar
Trader Rating: 74 (100%)
An 8" wide wheel in a +20 offset is going to stick out over 1/2" from the side of the car... to keep the wheels from smacking the fenders your going to have to run within 1/2" of factory height and have suspension stiff enough that you ain't going to want to drive the car daily.
The 17's with that tire size will ride like sh*t also... have you priced out tires in that size... I assume your talking about a 215/35/17...
Have you considered a 15x7 wheel with 205/50/15's or even 225/45/15's? Less cost, less unsprung weight, lots of wheel/tire choices.
McCoy is offline
Old 02-16-2007, 01:39 PM   #3 (permalink)
banned
Ok, If I go with 16'' rims, what is the lowest offeset that I can use without rubing the edges of fenders? Ideally I want 1mm of space between the inner edge of my fender and wheel. Maybe I sould get rota splitsream 16x8 +48 and buy some custom wheel spacers to fill up the gap.
these are the tires I was refering to. They are available in 205/40/16:
http://www.tirerack.com/tire-12/Yoko...a+Spec-2.shtml
FANTASY is offline
Old 02-16-2007, 01:48 PM   #4 (permalink)
McCoy's Avatar
For a 16X8" wheel, you would need to run a 20-25mm offset, any higher and you are physically touching the struts in the rear.
You could run a 16x7.5" wheel with a 37mm offset and run 5mm spacers in the rear to keep the wheels from hitting the struts... that's what I am currently doing for the winter wheels. The problem is that there are very few options for tire/tire sizes in a 16" wheel.
McCoy is offline
Old 02-16-2007, 01:55 PM   #5 (permalink)
banned
I already found the 16'' tires that I want, so the luck of choice is not a problem : )
FANTASY is offline
Old 02-16-2007, 02:10 PM   #6 (permalink)
banned
Is it a good idea to buy 16X7 for front and 16X8 for rear? I really want to see those lightweight Rota Splitsteam on my car? can anyone point out which set of rims form this list should I get? I want the rims as close to fender as possible and as wide as possible for the rear end.
16 x 6.5 +40/+45 4h x 100
16 x 7.0 +40/+45/+48 4h x 100
16 x 8.0 +48 4h x 100
FANTASY is offline
Old 02-16-2007, 02:18 PM   #7 (permalink)
McCoy's Avatar
Your front is not the issue, you have plenty of room up there, it's your back that is tight.
What suspension and how low do you plan having you car? Have you rolled and pulled the rear fenders yet, these are all factors on how wide of a wheel/tire you can run.
I think you need to start reading a bit more about what fits and what doesn't on a B13 chassis. Start in the thread below and skip all the stuff in regards to the B14 chassis... they are blessed with ample room in the rear for wheels/tires
http://www.sr20forum.com/showthread....ight=205+tires
McCoy is offline
Old 02-16-2007, 02:27 PM   #8 (permalink)
Drinking The H Juice Now
BigB's Avatar
You have lowering springs in the Front and STOCK springs in the rear????
Now you want to run 7" wheels up front and 8" wheels in the back?
Do you know ANYTHING about handling?
1992 SE-R WHT - SOLD
1992 SE-R BLK - R.I.P.
2001 -Mazda MP3 #60 of 1500
1991 Integra LS -
BigB is offline
Old 02-16-2007, 02:30 PM   #9 (permalink)
McCoy's Avatar
sh*t... I missed that. Your cars going to handle like ass, just a feeling.
McCoy is offline
Old 02-16-2007, 02:38 PM   #10 (permalink)
Seeing red
JimR's Avatar
For ultimate lightness, you might try some skinnies in front. Weld makes some 15x3.5" forged alloys in 4x100:
http://www.mazworxracesupply.com/pro... hed_4x100.htm
Then you could get some matching 15x10's to go in back and look really hot:
http://www.mazworxracesupply.com/pro...ls_4x1 00.htm
1992 SE-R / 1993.5 G20
JimR is offline
Old 02-16-2007, 02:50 PM   #11 (permalink)
banned
hahahahah lol...
the reason I waned to go with wider rear tire is because my car oversteers a lot after I installed 1&1/4 sway bar on the rear end.
FANTASY is offline
Old 02-16-2007, 02:53 PM   #12 (permalink)
Ser Charles
zerogravity's Avatar
I think what he had in mind were more to the staggered rwd look and not in handling. I had a similar set up and for street, you would hardly notice a difference until a few freeway highspeed turns where the UNDERSTEER set up really took in effect. I went away from the stagger set up because it was more economical to be able to rotate your wheels for me. In anyrate, to each his own. For looks i don't think the stagger look isnt all that bad.
www.cfxpaintworks.com
"There is one thing man should truly fear...it is the INDIFFERENCE of good men..."
My Set Up:
Motec Exhaust*Walbro Header*MSD Rims*Jim Wolf Custom Paintjob*Injen Tires*Mugen Glove Compartment*MazdaSpeed Bridgeport*Edlebrock Exhaust Bearings*Calum Power Mirrors.
Damn My Sentra Hauls!!! 93 Whp of PAIN!!!
zerogravity is offline
Old 02-16-2007, 02:59 PM   #13 (permalink)
McCoy's Avatar
Then go get an alignment and ask for more toe-in on the front of the car... that'll take care of the oversteer condition.
McCoy is offline
Old 02-16-2007, 03:12 PM   #14 (permalink)
banned
Also, what is so wrong with keeping the rear end stock? my next updadate is going to be reinstalation of OEM rear swaybar. The car was super balanced and predictable back then... I could skid sideways on any corner evenly without doing much of sttering correction and catching my rear end.
the point is OEM suspesion + low prifile tires is the best setup. Of course you can impve it but it is not something easy and trivial + it will cost you 3X more than an average B13 itself to get everyting right.
FANTASY is offline
Old 02-16-2007, 03:21 PM   #15 (permalink)
BigB's Avatar
You are absolutely right.. stock set up with low profile tires is best.
I bow to your expertise. The people posting in this thread do not know what the hell we are talking about.
Enjoy your car while you can.
Cheers and good luck in all your future endeavors.
Just don't ever expect any help from me.....
BigB is offline
Old 02-16-2007, 03:40 PM   #16 (permalink)
SE-R on a budget
15x7's....38mm offset.....205/50-R15...FTMFW It sounds like you are trying to rice
Born2Ride is offline
Old 02-16-2007, 03:41 PM   #17 (permalink)
banned
YES, Soft EOM suspention with low profiles is THE WAY to do speeding on a city road. Day to day I meet people with stiff suspesions and I laugh very hard while they bounce on the road bumps.
After all, the B13 is f*cking FWD car and there is no point of trying to make a candy out of crap. The only update that I am going to do to B13 in the near future is cutting all of the flors and installing OEM BMW motor/tranny/suspesion. This way I can f*ck anyone down the road.
FANTASY is offline
Old 02-16-2007, 03:42 PM   #18 (permalink)
Transplant was a sucess
Trader Rating: 6 (88%)
i love the 16 inch flat black slipstreams.
Whats your 0-60...? Fast.
1998 Nissan Sentra-SOLD
1971 Datsun 240z
2004 Nissan 350z 6MT
2007 Infiniti g35 coupe
1992 Infiniti g20 5mt
2003 Infiniti g35 sedan
(\__/)
(O.o )
n1smojunkie is offline
Old 02-16-2007, 03:44 PM   #19 (permalink)
SE-R on a budget
Make candy out of crap.....
Old 02-16-2007, 04:07 PM   #20 (permalink)
BnB
have fun going slow.
SR20DEEP CT
SE-Rious@vzw.blackberry.net
91 Sentra SE-R
Turbo
BUILT NOT BOUGHT 845 and 860's fastest SE-R's
money talks, bullshit walks
SE-Rious Dino is offline
Closed Thread
