Old 02-23-2007, 08:33 PM   #1 (permalink)
moe.ron
I have a SHORT!! HElp me, sugestions needed!!!!
OK, so aside from my previous headlight short that would cause the head lights to perodicaly go on and off with thempature drops when the car was off, i have a new short.
SO I was riding down the road a few days ago and it started, severl times a minit every so offten my BRAKE and BATTERY light will flicker on and off and sometimes stay on for a few seconds, whle at the gas station I looked up under the dash and jiggled wires. from that brief test the lights did nothing, BUT as soon as I left they continued. and IDEAS????
sorry about the bad speeling my spell check isnt working..
1991 SE-R restored DD 215,000k strong
1982 FIAT spider 2000 ??? DE-T in a fiat WTF???
kingofrock381 is offline   Reply With Quote
Old 02-23-2007, 11:13 PM   #2 (permalink)
wants to go play
Blair's Avatar
Your alternator is failing.
93 SE-R (daily driver)
Old 02-23-2007, 11:23 PM   #3 (permalink)
Lincoln Tech Grad
yea alternator
www.myspace.com/speedracer914
92 se-r (project spraypaint) - under construction
http://s56.photobucket.com/albums/g1...14/The%20Whip/
Mods:courtest fstb, progress adjustable rsb, place racing cai, pacesetter headers, hyperco gen 2 (to be installed), gti-r turbo manifold (to be installed)
hazardous is offline   Reply With Quote
Old 02-25-2007, 03:45 PM   #4 (permalink)
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
check your battery while the alternator is getting changed too.
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 06-14-2007, 02:19 PM   #5 (permalink)
bitemyshinymetalass
SuperblackZ's Avatar
Well that sucks as I have exactly the same problem. The flickering is just as described and started less than a month ago.
Since my battery is in the trunk I checked all the cables, made sure I had good ground up front, too, including MAF ground (which cleared up my idle issue last month).
Now I get this flickering which tends to go away (or not happen) under acceleration, happens mostly when backing off the throttle. I rechecked all the ground wires, the battery is pretty new (this year anyway), and the cables from the trunk appear to be in very good shape. It's all clean w/o rust anywhere and the cable insultator is like new.
Alternator makes sense, as the flicker also can be seen in the dome light when parked at idle; if I rev the engine just a little the dome light flickering stops. However when driving the car, the 2 dash lights (Brake and Battery) flicker when the engine could be at 5000 rpm backing off to 4000. I thought maybe the combo of UD pulleys and trunk battery was messing with me, but it was set up that way for a long time and works fine.
When I had the so-so ground last month turning on lights, stereo, radar detector messed with the idle - car would start to stumble at idle a bit when I put extra load with Acc's on it. Sounds like maybe the alternator is getting tempermental.
Thanks, hadn't really thought to look there since I have put 5k miles on the car since buying it running all kinds of juice to cell phone, radar detector, lights, etc. and I just figured usually when an alternator goes bad, it does not give you a month's warning. I'll check it out...
Former SCC Project SE-R
'91 B13 Black, JDM 10:1 CR SR20DE, Custom Intake/MAF w/JWT PopChg, 2.5" SSAC Header, Progress CO's 350F/250R, 3-way adj. 30-mm Progress FSWB, 22-mm Progress Rear Sway, Ground Control Plates, FSTB + FW triang braces, Progress LCA Brace, Energy Susp. bushings, Wilwood Brakes, Motgei Traklites 15x7", Kuhmo MX, RSTB w/triang trunk braces, R32 Steering Wheel
Team Progress
SuperblackZ is offline   Reply With Quote
