Originally Posted by redb13se-r
get a vise grip. grab a rag. put the rag around the knob so to not damage it. Now open the wise up by adjusting the screw to as wide as it will go. Adjust untill clamping it closed takes some force. Clamp that bad boy and use some muscle to turn it left. It should be a 10mm thread like most nissans have i believe. and youre done!
Or get a set of Channel Locks, plumbing deals.
Grab the beat up leather knob you are replacing. Replacing is important.
Carefully grab the knob, squeeze like a motherfu*ker. Twist, being carfull to not torque the actual shift lever itself.
Rip the leather completely off the knob. Curse. Inspect to make sure nothing got torqued wrong.
Re-grab knob. Curse again with gusto. Squeeze till veins pop. Carefully give it another twist, applying torque until you grunt and your eyes bulge.
The knob will then twist right off. Easy.
Replace with new shift knob.
That was my method.
