u can either get a new rebuilt on at autozone with a lifetime warrantee, or look for a used one in the classifieds. also junk yard if you're lucky. and it is pretty easy to replace, i did mine in like 30 minutes. loosen the two bolts, either 12 mm or 14 mm, take off bolts, unplug a few connectors take off starter from under car, put new starter in place, have a helper hand thread the bolts back in to hold the starter in place, plugs connectors on, tighten the two bolts, start engine, run 13's...
92 Dark Gray Sentra SER
92 Red Sentra SER
