Old 05-09-2007, 08:32 PM   #1 (permalink)
ERS spring question... looking for 250# springs
I am putting together my coilover setup, and I have decided on the following springs:
350# 8 inch front
250# 7 inch rear
I was looking through the eibach catalog and noticed that the lowest rate spring they list in 7 inches is 275 pounds. I cant seem to find a 250 pound 7inch spring? I know that several member running 200 pound 7 inch springs (aka 180.64.35) is there a special eurpean catalog that lists sub 275 pound springs in 7 inch?
My other option is to use an 8" spring in the rear, but I am concerned with wheel to perch clearance. Can anyone comment on this? I am looking for a stock to -1" drop.
thanks
-dave
92 Sentra 1.6T
dave_f is offline   Reply With Quote
Old 05-09-2007, 08:52 PM   #2 (permalink)
Professor Dingbat
Ground Control has the springs you seek on their website.
Old 05-09-2007, 10:12 PM   #3 (permalink)
I checked the ground control website ... 250 pound 7 inch werent listed
-dave
Old 05-09-2007, 11:34 PM   #4 (permalink)
Professor Dingbat
Dang, you're right. They have it in 8", but that's not what you're looking for.
Old 05-09-2007, 11:41 PM   #5 (permalink)
Trader Rating: 17 (100%)
That's strange. Aren't the rates set at 300/250 when you order a kit from someone other than GC, say from ebay or something? Those are the rates if you specify AGXs as your shock.
kioh is offline   Reply With Quote
Old 05-09-2007, 11:42 PM   #6 (permalink)
Professor Dingbat
I think 300/200 are the default rates.
Old 05-10-2007, 08:36 AM   #7 (permalink)
that whats so strange... 300 and 200 arent even listed in 7 inch. Did Eibach discontinue sub 275 pound springs in 7 inch length?
can anyone confirm that an 8 inch spring in the back will work without rubbing? do I need to modify the upper perch to fit an 8 inch spring in the back?
thanks
Old 05-10-2007, 06:43 PM   #8 (permalink)
I talked to Ground Control ... the springs are available, they said they will correct the website
-dave
Old 05-10-2007, 08:38 PM   #9 (permalink)
employed again
Dave,
I have *something* close to that at home in the shed. If you can give me a week, I'll check to see what they are.
Matt
MaddMatt is offline   Reply With Quote
Old 05-11-2007, 08:24 AM   #10 (permalink)
thanks Matt,
I placed my order shortly before my last post... I would still be interested in hearing about any spare springs you have.
-dave
