Old 05-11-2007, 01:40 AM   #1 (permalink)
Empire-CAT Machinery Tech
output seal leak!!!
a while back i replaced my axle with a new one, i didnt leak even with the old one... so a few months later it takes adump on me, starts leaking fluid on the left side trans seal, so today i put in a new axle seal, thinking i might of fugged up my old one... well anyways me and my buddy replaced it and is still leaking fluid, i think its the damn autozone new axle that is not machined to specs..
its a new beck arnley seal.... what do u guys think, bad axle??
and also is leaking from the right side lower sensor what sensor is it? it has a green rubber around it, and below the right side input shaft?
this shizz is pizzn' me of
2005 Infinity G35 Sedan 6M
2005 Nissan Titan SE 2X4 my DD
1991 clean white SE-R -Bone stock- another DD (second owner)
[b]91 Mint SE-R (third owner)
Mods: Black, Very Clean, Turbo. -weekend warrior-
SE-Riouse_93 is offline   Reply With Quote
Old 05-11-2007, 01:54 AM   #2 (permalink)
The Genesis
that sensor is the fifth gear position sensor(if its the one im thinking ur describing)
As with the seal, you can take the spring inside it, cut it a little bit and put it back in to create a tighter seal.
Old 05-11-2007, 02:39 AM   #3 (permalink)
employed again
Check those sensors. I've replaced both of mine (neutral and reverse). There is no such thing as a 5th gear sensor, BTW.
Matt
MaddMatt is offline   Reply With Quote
