Originally Posted by pathfinder7
Pathfinder is pointing you in a very good direction.
That is how to make your own CSK's. I also have that thread linked in The Suspension Thread (hehehe).
Thee best struts for our cars. If you can afford the CSK's, that is the way to go.
Originally Posted by jen36
if your budget is $800 dont settle for anything but roadmagnets or hyperco's paired with AGX's or CSK shocks. ABSOLUTLY EVERY OTHER SUSPENSION SETUP IS NOT WORTH THE TIME OR MONEY
this is "classicaddict" by the way
B132.0, you are in a fortunate position. There is a Group Buy on both Road Magnets and Hyperco's
right now. How lucky is that?
You could pair up either set of springs with a set of CSK's or AGX's and you would have a kick-ass, comfortable, quiet, performance suspension.
If you can $wing it, this is from The Suspension Thread:
Originally Posted by 98sr20ve
Oh, BTW, I am convinced with out a doubt that the absolute best daily driver+HPDE/autocross setup is the Koni paired with GC sleeves and a real front pearch the kills 99% of any rattles (all coilovers can make some noise). Pair that with a 300-325# 10 inch front spring, GC Camber Plate. Set the rideheight to and 1.5 or so below stock That leaves you with stock levels of suspension travel. I would stack it up against anything anyone else makes in the 1200 price range.
That dude ^^^ is Steve. He has considerable
expertise concerning our suspensions.
Notice the CSK (Custom Shortened Koni) utilized with a GC coil-over system. This set-up would fit your criteria, not sure on your budget.
Those are the options that I would point you at with your budget and performance expectations. You will have to research the current pricing, and figure out if you can do your own work on the CSK's, read up on those options (they're all covered in depth), look at the Group Buy prices, etc.....
Whatever you do, do it right this time. Do not let your budget be so set in stone that you make compromises. Save some more cash if necessary.
Best of luck to you.
