Originally Posted by Fatman489
honda 92-95 civic side skirts mount in a interesting way but im sure if your imaginetive enough you could make it work but would probably look like crap. i Own a 93 Hatchback Civic and the sideskirts have like 1/2 a million little monting things and the only way without hacking them to peices and using lots of bondo you could get them on is if you mounted them on the very bottem of the car (hard to explain what i mean but kinda like top of the sideskirt screwed to the floor pan type deal)
The honda sideskirts sits flush against the bottom of the door as a sort of "rocker panel cover"
On a nissan you would be mounting them to the bottom of the rocker panel instead, and putting them kind of in the way of the stock jack points.
Here is a picture example showing 94-97 accord skirts on a P10:
Chris
