Old 05-23-2007, 04:53 PM   #1 (permalink)
Get naked then get in
Tune up
I just bought a 93 Sentra SE-R. Its bone stock. I'm doing an overhauled proformance tuneup. Already did:
Denso iridium plugs
8MM accel wires
Fuel filter
Cap & Rotor
PCV valve
Oil system flush & change
Colant system flush & change
Changed tranny fluid
Valve cover gasket
What else is there to do? Also what will I see the biggest results with as far as starting after market parts? Biggest bang for my buck?
E-rocks nissans is offline   Reply With Quote
Old 05-23-2007, 06:13 PM   #2 (permalink)
Shift_Miss
http://www.sr20forum.com/general-sr2...questions.html
That should awnser alot of your performance related ?s
93' SE-R- I/H/E,NX2k brakes, RMs & AGXs
92' SE-R-Gone but not forgotten....
Matt64246 is offline   Reply With Quote
Old 05-23-2007, 08:08 PM   #3 (permalink)
Is an SE-R/VE a VE-R?
Hey Matt - if you do NASA autox's mayhaps we'll run into each other 6/17 (should be about right date) - coming up thataway to play with my kid (GTI). I run http://photo.angrylabs.com/main.php?g2_itemId=63
Erocks, couple things: Do not pass go, do not collect $200, (1) go get a set of standard copper NGK's. They'll deliver better spark, don't cost much, and just replace 'em a bit more often. all you get with these fancy metals is longer life but worse conduction. (2) Miko literally made me THROW AWAY my accel wires and go get a set of FACTORY wires (they're made by ND, as I remember) and just use those. (3) go to myoilshop.com and get 4 qts of MT90 for the gearbox. Absolutely hands down the best fluid change I've ever seen. The stuff is magic. I'm not exaggerating one iota. myoilshop is cheaper than most outlets. (4) Have fun. They're amazingly fun cars given their age. Anything you want to know is here, just learn to use the search stuff, and pay attention to the Technical Information Library up top of the main page.
'93 B13, etc.
do it over and over again?
Old 05-24-2007, 04:18 PM   #4 (permalink)
Where can I get ND wires or should I just go to Nissan and order wires?
