Remove all sparks and identify which cylinders are working. (One sparks should appear darker than other ones.) Swap sparks between a working cylinder and dark cylinder, let engine work for 30sec and remove sparks to find out if the good spark became dark. If it did, it means that your wires are shorting with engine (likely) or something wrong with distributer(less likely). If the swapped spark did not become dark, it means that the other dark spark is bad.
