Upgraded to AD22VF brakes, do I need a new MasterCylinder? - SR20 Forum
Old 07-10-2002, 12:31 PM   #1 (permalink)
Resto 99% complete
I installed the NX2000 brakes without a problem. While browseing some sites I read that you have to change the Master Cylinder also. Is this required? I drove the car with the new brakes and they feel ok.
THanks
Keith
- Keith
'92 SE-R
keith455 is offline   Reply With Quote
Old 07-10-2002, 01:33 PM   #2 (permalink)
now on the West side!
NismoSER's Avatar
Feedback Score: 17 reviews
No, you don't have to change the MC. Its a matter of preference, I believe they swap MC's just to get the brakes proportioned differently.
Chris
'91 VVL-powered SE-R SOLD
'04 G35 6MT
Old 07-10-2002, 03:05 PM   #3 (permalink)
little Thunder
nismo91's Avatar
Feedback Score: 4 reviews
No need to change MC, I believe. Ask BlackB13 (Steve) he recently upgraded his Classic to AD22 and a DET.
= = 91 Classic = =
nismo91 is offline   Reply With Quote
Old 07-11-2002, 11:27 AM   #4 (permalink)
RUST?!? It's Character!
No Biggie
Completely optional.
SCC's take on this (Kojima's too IIRC), and i concurr as well, is any additional pedal mush can be cured w/ good bleeding and some stainless brakelines. Sure you can achieve a slightly better f/r balance but cost/benefit really doesn't add up. The fronts still lock first (safer)
Now if yer runnin a DET or VE on a road course regularly then it might be worth it. At that point *** i would be lookin at even bigger aftermarket; fixed calipers, 4 piston, etc.
I'll pimp anything......good.
94 BMW 530iT&A 125K, ‘Helga’ ( for sale *sniff* )
92 BMW 325i 125K, ‘Rolf’ ( he’s baaack *whoohoo* hers *sigh*)
91 Volvo 745T 191K, ‘Thor’ ( 13 psi *grunt*)
93 Datsun NX2000 160K ‘Carla’ ( alive & thumpin *uNfff!* )
85 Toyoda MR2 123K ‘Jerry’ ( so fresh and so clean clean *grin* )
”Bet that phone call doesn’t seem important now, eh?” Nov 20, 2004
paul p is offline   Reply With Quote
Old 07-12-2002, 08:37 PM   #5 (permalink)
employment whiplash, NC
I've got ~a 1.5 years of autocross and track schools with NX brakes and stock SE-R MC. No complaints, couldn't be happier.
Matt
MaddMatt is offline   Reply With Quote
Old 07-15-2002, 07:34 PM   #6 (permalink)
JDM BOOST WHORE
SR20 91 SE-R's Avatar
Feedback Score: 12 reviews
how much bigger are the nx2000 brakes from the se-r? is it worth it and how much dose it cost 2 swap?
SR20 91 SE-R is offline   Reply With Quote
Old 07-15-2002, 08:09 PM   #7 (permalink)
Yes Dear.
Feedback Score: 6 reviews
they are very beefy. and lets just say.. your stock 14 wont fit. hehe.. unless you do some grinding.
its would be about 150-200 with core exchange. im saying its this much because you will need the NX rotors prefferably the ones with abs. because they are thicker i believe at least 3mm.
uh..but its probably one of the upgrades you can do for the money
Sr20kidD is offline   Reply With Quote
Old 07-16-2002, 03:28 AM   #8 (permalink)
no....i have already done this swap and no its not needed..
sunnysupersaloon is offline   Reply With Quote
Old 04-20-2005, 07:45 AM   #9 (permalink)
Is an SE-R/VE a VE-R?
Will using the NX MC bring the pedal back up to where it was before the swap? (It's only about a quarter inch difference, perhaps due to the larger volume of the AD22VF calipers).
Old 04-20-2005, 08:27 AM   #10 (permalink)
Pâté Performance...
Very well worth the $!!
Home of the low (Original) Mileage B13
1992 B13 SE-R - Original Owner. 66K
2004 Avante XD2 GT - DD
2000 Miata LS - Top Down Fun!
MY SIG PIC ------------> http://i34.photobucket.com/albums/d1...31/SE-REGT.jpg
Originally Posted by Octave236 View Post
Uh i believe your contridicting yourself. B13's are highport motors unless a lowport was swapped in.
CleanSE-R is offline   Reply With Quote
Old 04-21-2005, 04:25 PM   #11 (permalink)
You got SE-RVE'd!
You can adjust the amount of play the brake pedal has, this may take care of the difference you feel. After I adjusted the slop out of my brake pedal, I couldn't be happier with the feel.
alembicf1x is offline   Reply With Quote
Old 04-21-2005, 04:28 PM   #12 (permalink)
You got SE-RVE'd!
THanks
Keith
It depends on whether you trail brake or not. I have found that the brake bias moved ever so slightly to the front, which means the rear is slightly more difficult to rotate when trail braking. This may be cured by switching to a more aggressive pad in the rear or by switching the master cylinder or even by upgrading to a larger rear caliper/rotor.
Old 04-21-2005, 05:13 PM   #13 (permalink)
my thoughts http://www.sr20forum.com/general-sr20/111647-nx-brakes-hurt-your-stopping-distance.html
Old 04-27-2005, 11:27 PM   #14 (permalink)
sno
i've got a set of polished calipers and brackets i'm sellin for $225 +shipping.
sno is offline   Reply With Quote
Old 04-28-2005, 11:32 AM   #15 (permalink)
Feedback Score: 5 reviews
I'm running AD22 on my classic SE-R with my stock MC and it works fine. Huge difference in stopping.
Tim
Allmotor is offline   Reply With Quote
Old 04-29-2005, 11:19 AM   #16 (permalink)
OH. Duh. (THANX)
J
Old 05-07-2005, 11:15 PM   #17 (permalink)
You're Ugly!
Feedback Score: 18 reviews
im planning on doing this upgrade this summer after my det swap and i want to know if you can use your stock se-r brake lines? i have braided steel lines so i dont wanna through them out.
SR20DEEP CA
shingouki1 is offline   Reply With Quote
Old 05-07-2005, 11:34 PM   #18 (permalink)
banned
Black Stallion's Avatar
Feedback Score: -1 reviews
yes you can
Black Stallion is offline   Reply With Quote
Old 05-08-2005, 01:10 AM   #19 (permalink)
Coropate greed hater
Feedback Score: 3 reviews
I never changed the MC on my SE-R. Never had a problem, either on the street or on the roadcourse. However, I have head that pedal effort with the NX MC would be a bit less than the SE-R. I wouldn't know for sure though.
-The Usual Suspects
Old 05-10-2005, 01:26 PM   #20 (permalink)
Pedal feel and modulation CONTROL of threshold braking is actually a bit better with the smaller diameter plunger of the stock MC. Pedal effort is supposed to be actually higher with the bigger MC. Having done it, personally would like a bit more at the rear than stock, have heard doing a 92 or so Maxima SE caliper and the 10.2" rear abs NX rotor helps (a straight bolt-on), but I notice Matt et. al. at Carbotech don't do the Bobcats for that particular caliper and I'm WAY too happy with those pads. Sigh.
