I would guess that a shop would charge 1 to 2 hours labor. Labor rates in your area might be $75 to $100 per hour, I don't know. Why not get a couple estimates from shops? Then you will know for sure.
It's straight forward to do, but nothing is easy on a 14 year old car. There are a couple things that can go wrong if you do it yourself. You might have trouble getting the O2 sensor out of the old exhaust manifold, you could break off a stud in the head (they can get weak with time), you might have trouble getting the EGR pipe out of the old header, you may have difficulty getting the EGR threaded into the new header, and you may have a hard time taking your old downpipe off your cat due to corrosion.
All of these can be dealt with, and the Forum community is here to help. But you will need to make sure that you can safely jack up the car and that you have the proper tools. And it would not be smart to jump on your first header install expecting it to only take an hour or two. Do your prep, take your time, and you will do it right. Otherwise, just have a shop do it and Enjoy the Ride.
