Did the b13 SE-R come with pinstriping from the factory as an option? My car has some,and I've seen plenty of others. If it is stock,I want to leave it. Otherwise,it's coming off. I guess I'm a purist like that.
i had these on both a 91 and 92 SE-R that i had, spent almost a day removing the pin stripes on each car, since you could not easily pull it off because the vinyl was so brittle and would break off in milimeter increments.
i personally don't like any pin stripes of any kind, like my classics clean
Cars (91's anyway) didn't come from the factory pin-stripped. Mine was done at the dealership.
'91 SE-R, Original owner, PowerSlots, Axxis MM, Magnacore, Michelins, Autolite APP3924's , Stromung cat-back and 80K orig miles. Spring '06 work: GR2's and boots with orig. springs, ball joints, TR ends - inner and outer, ES front CA bushings, CV joint rebuild.
