Old 02-01-2008, 10:12 PM   #1 (permalink)
Can't get into 1st, 2nd gears, taking off on 3rd!!
This used to be an occasional problem, where every once in a while it happened that I cannot get into 1st and 2nd gears, but if I force to go in, it will be fine. It used to happen once every couple of weeks, for the past 1 year.
This time, I cannot force it anymore to un-jam, whatever was jamming in there. I cannot shift into 1st and 2nd anymore at all.
I did some search on the forum. I adjusted the clutch pedal cable. Tried to shift to first, by holding the rod from under the car (to eliminate any shifters issues, or trany shifting out of line with the rod, as I read in some posts) but to no do.
I checked the tranny fluid by trying to add some, but it did not take any fluid (even though there is a minor leak from the driver side input drive shaft seal!!) Is there a separate fluid compartment for 1st and 2nd gears!? I know it doesn't make sense, but the only thing I can think off, is that 1st and 2nd gear might not be getting any fluid from the leak.
At the same time, the car started grinding in 5th gear, and then started popping out from 5th gear. The f5th gear pop-out was fixed years ago, and now it is back.
It looks like it is not worth fixing anymore!! Maybe I should start looking for another one. It's an LSD on a 92 SE-R and a short shifter, redline shockproof.
Being my only car now since I totaled my TTZ, I have no choice but to take off in 3rd gear ... not fun at all ... good thing the area I live in is mostly flat!!
Thanks for your input on any advice or suggestion I might have missed!!
RIP RIP RIP RIP RIP RIP RIP RIP RIP RIP RIP RIP RIP RIP RIP RIP RIP RIP RIP RIP RIP RIP RIP RIP RIP
TTZ-SR20 is offline   Reply With Quote
Old 02-02-2008, 01:29 AM   #2 (permalink)
BnB
i'd say get a whole new tranny. that Z is beautiful.
SR20DEEP CT
SE-Rious@vzw.blackberry.net
91 Sentra SE-R
Turbo
BUILT NOT BOUGHT 845 and 860's fastest SE-R's
money talks, bullshit walks
SE-Rious Dino is offline   Reply With Quote
Old 02-02-2008, 05:13 AM   #3 (permalink)
You mean a used one from the forum ?
I'm not familiar with the SE-R prices. What would be a fair price for one ?
Old 02-02-2008, 11:29 AM   #4 (permalink)
SE-ARRRRRGGGGHHHHHHH!!!!!
Wait, that's not a 92 SE-R in the picture. Hey! What are you trying to pull here????
nobbie is offline   Reply With Quote
Old 02-02-2008, 11:29 AM   #5 (permalink)
BnB
yea used one. they go anywhere from like $200-$350 depending on mileage and if there's pop out or anything.
Old 02-02-2008, 11:44 AM   #6 (permalink)
SR20DEbT
Trader Rating: 53 (100%)
I had a tranny do this to me before. It may eventually lock itself into gear and you won't have a choice but to get a new trans. I say go to a local pick and pull. I also see some B14 transmissions go for like 300-350$ on the forum so thats your best bet.
-Bes
92 Sentra GTi-R
Small Snail Crew
----BNB----
Old 02-04-2008, 10:11 PM   #7 (permalink)
Project Achilles
my tranny did this exact same thing to me. keep driving around like that and something in the tranny will eventually break and you'll left like i was to limp the car home and park it until you find a tranny. begin your search for a tranny now before it is too late and you're left stranded. i got my replacement tranny out a p10 g20 at the local pull and save for $50. but be aware that when you get a tranny that you know the difference between the lsd and non-lsd tranny before you get one. you'll need a different driver side axle if you get a non-lsd tranny.
Originally Posted by Shawn B
Go get laid. Seriously. Cheap, casual, one-night stand, primal porno, monkey humping. Sympathy sex. Excellent for your ego, good for the soul.
Originally Posted by JDM Freak
"yeah.. first gear is regular, second gear is vtec, third gear is JDM, and fourth gear is GSR"
Originally Posted by 95p10
by this i mean go ShawnB on his ass and make him bleed out his eyes.
lukamccloud is offline   Reply With Quote
Old 02-04-2008, 10:59 PM   #8 (permalink)
It's not worn-out motor mounts?
'93 SE-R - VE Powered
'02 G20 Sport - Slow but comfy
http://www.cardomain.com/ride/102760
Dan_93SER is offline   Reply With Quote
Old 02-04-2008, 11:34 PM   #9 (permalink)
maybe your throw out bearing isnt good?
Team Optimum
0-60 in 5 minutes
Wht91SE-R is offline   Reply With Quote
Old 02-05-2008, 03:24 AM   #10 (permalink)
No .. motor mounts are fine. But thanks for the suggestion.
Old 02-05-2008, 03:27 AM   #11 (permalink)
Wouldn't that affect all the gears, not just first and second!?
I would also think, a bad throw out bearing would not allow the clutch to engage at all in any gear, as it would not allow the pressure plate to retract against the clutch disk!?
