Hey what's up guys.I need a little assistance.I 'm allways searching these forums so forgive me if it may seem obvious to you.I'm currently building my second sentra.This time it's a gtir powerd b13 se-r.The tranny that came with the car had no 5th gear and I doubt it had lsd.I pulled a 95 g20 motor with the tranny and ecu/harness the other day so I decided I'd use the tranny in the swap.I think it has lsd but I'm not sure "cooling fins" I will take some pics.From what I gather I need 98-99 200sx se axles or 2001 se axles lsd or not.Correct?And also the gtir block has no axle carrier bearing but from what a read you can use the old one but only use 2 bolts.I still have yet to figure that one out but I will play with it some more.The other motor had a 5 angle port and polish vavle job from hocus pocus 1mm oversized valves titanium springs cam gears and c3 cams.About a 3000$ head I'm about to let go after inspection from a machine shop "head gasket let out and coolant compressed inside the motor boom!".It was about 240hp all motor.Oh yeah,the g20 ECU is for sale whoever wants it.
