Originally Posted by G20SR20det
thanks bro, i just got back from dmv and the dealer $50 bux a pop for the hinges.
When you have some time to order parts, you will want to find a discount source that works for you. $50 for a hinge seems a bit rich.
Check this out:
http://www.sr20forum.com/nx2000/2208...ts-nx2000.html
There are also specific instructions on this Forum about how to change out the hinge. You might want to check out the Technical Library or just search on "door hinge replace" and see what you can find. This is a commonly done job. Chances are that your heater fan doesn't have all it's speeds, either. That's another common and easily fixed problem.
Search the wealth on information on the Forum. Enjoy the Ride.
