wanted to remove the a/c pump but the belt then needs to be shorter. i can tell its a 6 rib belt but i need a part # for length.i can always do the old string trick but if anyone knows i can just pick one up.thanks
You can get a belt for a car w/o air and its going to be a 4 rib 33" belt. You can get a 6 rib belt too, same length. The part number for a Dayco belt from advance will be 5060330.
E36 BMW 325is
P10 Infiniti G20
2009 Aprilia SR50 R Factory
Its kinda tricky, or at least it was for me, a 32.5" belt was way too loose, a 29" belt, way too tight. SO, I modified the adjuster bracket by extending it and made a 6 rib 29" belt work. 2 weeks so far so good.
1968 Datsun 510 - 2.2L Z22E (EFI, SOHC) Soon to be ***KA24DE***
1991 Nissan Sentra SE-R I/H/E/AGX/GC ***SR20DE***
