Old 02-14-2008, 07:25 AM   #1 (permalink)
Project Build
Noob Question... Help Though
I need help locating the idle control on my se-r
not that familiar with the car if someone could post up a pic or kinda of explain where its located?
91 Sentra SE-R [B13]
07 Altima 3.5 SE
91B13559 is offline   Reply With Quote
Old 02-14-2008, 12:44 PM   #2 (permalink)
KASSANOVA!!!
Trader Rating: 37 (100%)
passenger side, under the intake manifold. it should be on the edge, and has a flat head screw popping out of it. i had a hard time finding it at first, but it was because there were wires blocking it.
92 Dark Gray Sentra SER
92 Red Sentra SER
Old 02-17-2008, 07:02 PM   #3 (permalink)
Project Build
ok thanks for the help.
Old 02-18-2008, 08:40 AM   #4 (permalink)
Search and learn. Don't be turning that adjusting screen willy nilly without putting the engine in Adjust Base Timing Mode. That's asking for trouble.
This will get you started....it's mostly about timing but talks about idle also....
http://www.sr20forum.com/technical-i...ur-timing.html
